Question about stretch tires
Old Mar 27, 2012 | 08:50 PM
scarface514's Avatar
Hi, i am getting 20" rims 8.5 in front and 10" width in the back, i need to know the size or how to get stretch tires can somebody plz help me out
Thanks!
Old Mar 27, 2012 | 09:01 PM
chink-ah-saur's Avatar
8 and 10 back
Old Mar 27, 2012 | 09:17 PM
DrewDrew's Avatar
odd widths, but the only real option you have up front is a 225/35 - which is barely a stretch at all. the equivlant out back would be 255/35.
with those weak widths, what are your offsets? chances are you don't even need to stretch, unless you're running large spacers in the negative offsets. need to know if you have a coupe or sedan too.
edit: your post in the "questions about wheels/tires" thread shows you have a sedan. I can't help with the offsets.
Old Mar 28, 2012 | 04:25 PM
4DGS's Avatar
Better way to go about this is.... buy a full set of rears and run 10s all the way around!
Old Mar 28, 2012 | 10:04 PM
if i had a g35x i would of went 10s all the way, i kinda like the look when the rear wheels are lager then the front
Old Mar 28, 2012 | 10:09 PM
Thanks for the reply
so i have a sedan
i dont no if this would help u?
Size - Front 20 x 8.5 / Rear 20 x 10.0
Bolt Pattern - 5 x 114.3
Offset - Front +38 / Rear +42
Centerbore to fit - 73.1mm
so wat ur saying is i should go for 225/35? cuz i just like the look when its stretch out
Old Mar 29, 2012 | 12:55 AM
4DGS's Avatar
You're confused man.
You can't stretch **** onto an 8.5" wheel not to sound like a dick here but this isn't a honda. You need to run some width when you're dealing with 18s and 19s.
You need MINIMUM 9" up front and 10" out back to pull off a staggered stretched look. Either that or don't stretch at all because it will look like straight up ****. Like I said 10s all the way around is your best bet, and as long as the rear is a little more aggressive I'll bet you your car you won't be able to tell they aren't staggered.
Old Mar 29, 2012 | 09:23 PM
yes im confused dats why im here asking questions
and i orded my rims already so i guess i cant go for stretch tires
do you know a good tire size i should get if i want them not too low profile and have the rear wheel look wider thanks
Old Mar 29, 2012 | 09:42 PM
J2S2M's Avatar
Yeah. Stretching would very unnecessary with those weaka$s offsets even on a sedan. Just slap on some 245/40/20s 275/35/20s for the rear. Call it a day
Old Mar 30, 2012 | 02:01 PM
4DGS's Avatar
This
Old Mar 30, 2012 | 02:11 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Wrong tire sizes, for a V35 you want 235/35/20F 275/30/20R
Old Apr 1, 2012 | 05:14 PM
thx for all the help i appreciate
wats wrong with 225/35/20 n 245/35/20 just curious cuz i saw some nice v35 with those on
vitamin.v
Nov 7, 2019 06:10 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
mushu
Jul 15, 2015 03:55 PM
