Hubcentric rings ???
Old Jan 11, 2005 | 11:59 AM
hp1000's Avatar
Question Hubcentric rings ???
Hi everyone,
This is for all the people that put aftermarket rims, did you guys have to put hubcentric rings or not.
Thank you in advance,
Old Jan 11, 2005 | 03:14 PM
Boon's Avatar
I did on mine. Many aftermarket wheels require them for proper fitment.
Old Jan 11, 2005 | 05:04 PM
Gsedan35's Avatar
Unless the wheel perfectly fits the center flange absolutely yes. You will want to find them made out of metal, hopefully aluminum. Avoid the plastic ones as brake head and destroy them.
Old Jan 11, 2005 | 05:08 PM
waijai's Avatar
i.love.gold
Mine came with hub rings.
Old Jan 11, 2005 | 05:16 PM
Brando's Avatar
I think almost all Volk Racing wheels come with them.
I know mine did.
Old Jan 11, 2005 | 08:10 PM
GoSooners's Avatar
Where can one find aluminum ones?
Old Jan 12, 2005 | 01:47 AM
tgalvez's Avatar
I dont think they make them in alum...
I got mine today from iforged and they are plastic
Old Jan 12, 2005 | 04:23 AM
romanwarrior's Avatar
I know mine did.
Volks do not come with hub centric rings. You can buy it from them though.
Old Jan 12, 2005 | 04:24 AM
HGS_G's Avatar
Aluminum hub rings
Here ya go. My friend recommended these after he noticed some warping to his front plastic ones that came with his Volks after a weekend at the track. I switched my out after I saw his warped rings. Just make sure you brush some anti-seize on the rings before you install them on the wheels and hubs unless you want them on there for good. Hope that helped.
http://stores.ebay.com/Discount-Tire...QQftidZ2QQtZkm
Old Jan 14, 2005 | 11:16 PM
rijowysock's Avatar
my new SSR came w/ aluminum hub rings that are threaded.. they twist into back of rim kinda like a nice watch back.lol...pimp****.eh
aywho. u need em.. even if they are the plastic ones
Old Jan 15, 2005 | 12:08 PM
reggiek's Avatar
hubcentric rings
Originally Posted by hp1000
Hi everyone,
If a wheel is custom made it may not need rings. HRE makes their wheels to fit exacting specs of the car. I heardh iForged will do so if requested. For manufacturers to make wheels custom for every car would increase the cost. SO they make wheels to fit many cars and all they need to complete the fitment is that hubcentric ring. I've used aftermarket wheels about 15 years and have no problem with the rings.
Old Jan 16, 2005 | 11:12 AM
6969g35's Avatar
From: FROM BROOKLKN NEW YORK NOW LIVE IN VALENCIA CA.
maya wheels come with exact specs too fit perfect
no ring no vibration
over 100 no vibration
Old Feb 11, 2005 | 07:46 PM
wreck's Avatar
Running for his life!!
Originally Posted by HGS_G
Thanks for the link. Got them today and installed them. Definately help with the vibration I had. My rear's didn't need them, but my fronts did.
Tip for people using aluminum rings, make sure you put anti-sieze grease. Or else the heat will make the rings stick to your hub and the dealer or whoever will have a difficult time changing your rotors.
Old Feb 11, 2005 | 08:13 PM
LivyathanZero's Avatar
thanx for answering my question 6969, I was going to ask if Maidos came with them as I'm getting the 20" RT5 Graphites.
Old Feb 12, 2005 | 11:45 PM
Paul1082's Avatar
does anyone know if the nismo LMGT4s need hub rings? thanks
