3mm Spacers - Hubcentric Required?
Old May 29, 2012 | 05:34 PM
FantastikG37's Avatar
As the title states, are hubcentric spacers required for 3mm spacers? Upon some research, it seems like the wheels will still be able to sit on the center hub of the car with 3mm lugcentric spacers. I did find a shop that can custom make 3mm hubcentric spacers that will be hubcentric to the car and wheelcentric to my wheels for around $85. Would this be necessary or would I be able to get by with lugcentric spacers for about $25? I have already ruled out those universal 3mm spacers.
Reason I need 3mm spacers is for my wheels to clear my front brakes. Thanks in advance!
Old May 29, 2012 | 05:39 PM
Jaygotboost's Avatar
IMO dont go cheap on the car even if its 3mm spacers, if they can make it hub centric go for it and not risk any wheel wobble
Old May 29, 2012 | 05:55 PM
VMRWheels's Avatar
Honestly for the price difference I'd go for hubcentric spacers. Buy once, cry once! You don't want to have to go back and do things right the second time when you could have avoided it the first time.
Old May 29, 2012 | 06:23 PM
Thanks for the input. Another question.. would extended studs be required when using 3mm spacers?
Old May 29, 2012 | 06:25 PM
no, anything over 5mm requires extended studs
Old May 29, 2012 | 06:26 PM
VMRWheels's Avatar
Lots of people run 3-5mm spacers without extended studs, however if possible I'd always recommend getting studs that are 3mm longer than what you are using now.
Marlin84
Apr 1, 2020 12:52 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
dcsbh1
Oct 1, 2015 03:15 PM
