245/45/19 instead of 245/40/19 in rear ok?
Old Jun 6, 2012 | 07:54 PM
carlo107's Avatar
Hi sorry if this sounds like a really dumb question but I can't seem to find anywhere if putting 245/45/19 tires on the back of my 2007 g35 coupe is okay. The stock ones are 245/40/19 so I was just wondering if it will be okay to put a thicker side wall because I found a good set of used ones. My car is lowered an inch and half so will there be any rubbing issues or anything? Thanks in advance.
Old Jun 6, 2012 | 08:00 PM
VMRWheels's Avatar
245/45/19 is a very tall tire. I would not put those on a coupe, you could rub and it'll increase brake wear.
Old Jun 6, 2012 | 08:01 PM
carlo107's Avatar
They came off of a g37 coupe. Is there that much difference between the two cars that they won't work?
Old Jun 6, 2012 | 08:26 PM
VMRWheels's Avatar
245/45/19 instead of 245/40/19 in rear ok?-tyuau.png
Pretty big height difference...
Old Jun 6, 2012 | 08:35 PM
carlo107's Avatar
Yeah its half an inch. Has anyone actually put 245/45/19s on their car? If so please let me know how they worked. Thanks in advance.
Old Jun 6, 2012 | 08:43 PM
Frankieg35's Avatar
Why would u want that much sidewall?? I just dropped down to 35 series and it looks much better..
Old Jun 6, 2012 | 08:45 PM
carlo107's Avatar
Only because I found someone selling a used pair for $150 with decent tread. I wanna make sure they would be ok first though.
Old Jun 10, 2012 | 11:16 PM
RCL's Avatar
RCL
It should be fine. The car might ride a tad nicer as well.
Old Jun 11, 2012 | 03:09 AM
4DGS's Avatar
No.... buy the right tires, don't be cheap.
Old Jun 11, 2012 | 05:31 AM
kartkid's Avatar
I ran that set up for some time and it is within the the limits to not set off the vds
I found it to look better and fill the wheel well better and no problems rubbing..
Old Jun 14, 2012 | 06:39 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Best to run the correct size rather than mess up the VDC and have rubbing issues. 245/40-19 better size.
Old Jun 25, 2012 | 06:02 PM
swoo35's Avatar
Im running 245/45/19 in the rear and its fine no rubbing, but my car is stock not lowered.
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
derres
Aug 28, 2015 03:27 PM
Footballmania32
19 Inch
Aug 13, 2015 03:07 PM
