Need Info on how to understand offset and lip size?
Old Jan 15, 2005 | 03:58 PM
dj prophecy's Avatar
Hi
I am sorry if this sounds like a really dumb question, but I am lost when it comes to the Dimensions of rims.
I am looking for rims that have a nice 2 inch lip in the front and about 3 inch lip in the back, How does that equate to OFFSET ?
Also I have a Coupe 5AT and i want to use my stock tires jsut want to change out my stock rims to WORK SS - VV rims.
THanks in advance
Old Jan 15, 2005 | 04:04 PM
Also when they say a rim is 18 x 8 that means the rims i 18" in diamater by 8 inches WIDE correct?
Then where does the bolt patterm dimensions come into play?
I know x4 is 4 lug and x 5 is five lug but whats the number in front of the x 4 represent
Example : 114.3 X 4.
What does the 114.3 represent?
thanks
Old Jan 15, 2005 | 05:08 PM
smokeator's Avatar
114.3 represents the bolt pattern for that wheel ie what its's drilled to.
Offset: The distance from the centerline of the wheel to the mounting surface of the wheel.
Here is a picture to show wheel terms to make this understandable as I did'nt know anything about this either before the G.
Old Jan 17, 2005 | 11:46 AM
Thanks smokeator that clears up a few things, would you happen to knwo what exact dimensions I would need to get a Wheel to have a nice 2 inch lip up front and a nice 3 inch lip in the rear using the 18 inch pilot tires?
Old Jan 17, 2005 | 04:59 PM
avs007's Avatar
I don't think you can get a 3 inch lip in back with your stock tires. At least not with a Work Rim. My Work Meister S2R have about a 3 inch lip in back, but it's an 18x9.5", which is probably too wide for the stock 245 tires. I'm running 275 tires on them. My front rim is 18x8.5" and I mounted a 245 tire on it, but the lip is 2 inches. And the stock 225's were already stretched on the stock 8" rim, I don't want to know what it'll look like on an 8.5" rim.
Old Jan 19, 2005 | 01:43 AM
ChazM's Avatar
I can't remember, is it the higher the mm for the offset, the more the rim sticks out?
I would want mine to be flush of course and I've noticed many sizes are available in the low 20's mm for 19's, would that be fine?
Old Jan 19, 2005 | 08:41 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Hi
I am looking for rims that have a nice 2 inch lip in the front and about 3 inch lip in the back, How does that equate to OFFSET ? ....
Info above answers most of your question.
FWIW here is some info RE: Lip size..............
While offset & rim width definitely have an effect on available lip;
Lip size is also related to the design of the wheel face.
If a design has more curve to it, this will give you more lip.
Some wheel makes (usually multi piece) offer different faces for the same wheel.
eg. Volk SF Winning come in three faces (A,B, & C)
each has a different curve.
Face curve or shape also impacts brake caliper clearance.
I think Volk recommends face "A" for big brake applications.
(flatter = less lip)
Old Jan 19, 2005 | 12:03 PM
CLS2G35's Avatar
Many companies refer to the face as disk. High, Medium, Low disk. Some even have super high disk.
Old Jan 19, 2005 | 01:33 PM
Awesome, thanks for the information I have no changed my mind to go witht he PIAA super Roza multipiece rims. I will most probably go with the 19inch 19x 9 fr 19x 10 rear setup. I will have to see if there are different faces for this rim. Great information guys, i appreciate it.
Old Jan 19, 2005 | 05:02 PM
avs007's Avatar
Since you said earlier you were looking at Work Rims... They have 2 styles. "Big Disc" and "Deep Dish". You can probably figure out which one has the bigger lip...
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
StreetStandard
Wheels & Tires-Vendor
80
Aug 30, 2016 01:21 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
