Will these 18's fit?
Old Jan 15, 2005 | 09:59 PM
GReddySetGO's Avatar
OK, I might buy some new rims, and this was the setup I was going with, just wondering if anyone knows if this will work out w/o rubbing etc.
Front: 18x8.5 +24, 245/40
Rear: 18x9.5 +25, 275/40
Not sure what I'm gonna drop it on yet, have to measure the wheel gap after I get them. Any thoughts?
Old Jan 15, 2005 | 10:49 PM
avs007's Avatar
Those will work no problem. You can go a little more aggressive on the backs probably. Mine are F:18x8.5"/+25mm and R:18x9.5/+20mm, and they are nice and flush. I don't have brembos but I have plenty of clearance between my calipers and the spokes. I don't know what rims you are looking at, but when I got mine, I was going to go with +25mm offsets all around, but the store told me if I got the back rims with the same offset (+25mm) as the fronts,the lip would not be bigger than the fronts, despite being a wider rim.
Old Jan 15, 2005 | 11:44 PM
lowrider's Avatar
You'll be fine. BTW, I would not be more aggressive with the rear offset. The Nismo rear is also a 9.5" wheel and is +30mm, which I think is just about perfect.
Lou
Old Jan 16, 2005 | 06:04 AM
Cool, thanks for the info guys. One last question about lug nuts, ours are M12x1.5?
Old Jan 16, 2005 | 08:22 PM
avs007's Avatar
I guess it really depends on the rim, as to which offsets are optimum, because +20mm is the published recommended wheel fitment for my Work Meisters. Just ask the place selling the rims. I've seen the recommended fitments being anything from +20 up to +35, depending on the wheel.
As for the lugs, M12x1.5 is not the correct size. Our lugs are M12x1.25. I had to buy the spline drive tuner lugs and locks, because my old locks and socket didn't fit the lug openings of my new rims.
Old Jan 16, 2005 | 08:47 PM
Cool, I'm gonna get Spline Drive lugs too. So M12x1.25 is the size, thanks a lot!
My friend has the same rims/tires/offsets I want on his 350Z, so thats where I got them from. If they work on his car, they should work on mine too, right?
Old Jan 16, 2005 | 11:29 PM
avs007's Avatar
Yeah, M12x1.25. I double checked with the box my lugs/locks came in. And yes, if the rims fit the Z, it'll fit your G
Old Jan 17, 2005 | 09:55 PM
Thanks guys, I'll be posting pics when I get them
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
dseet
Oct 11, 2015 12:40 AM
Claudiu
Sep 26, 2015 01:04 PM
