Vehicle Alignment *Please Help*
Old Aug 3, 2012 | 04:23 AM
JoshuaW80's Avatar
So I have a 2004 G35 coupe and I need help with trying to figure out the perfect specifications to my wheel alignment. I'm pretty new to this so bare with me!
Below is the vehicle alignment report I currently have.
As you can see I have negative camber on my front and rear wheels. I know that having negative camber can cause tire wear and I have seen it on my tires. I dont want to have to keep going through tires, I want the ones I have to last for a while, but I do like that negative camber adds to cornering and handling. What I want to know are some specs that would be just a tad bit negative camber but not too much to where I'll wear my tires. Thanks for your time and please help if you have any information.
Old Aug 3, 2012 | 04:47 AM
thescreensavers's Avatar
Mr.202?
Are you lowered?
Old Aug 3, 2012 | 05:05 AM
ilovez33's Avatar
Jeez....Your toe alone was killing your tires.......
Old Aug 3, 2012 | 12:18 PM
JoshuaW80's Avatar
Originally Posted by thescreensavers
Are you lowered?
I was for a while until yesterday but I'm going to re-lower it.
Old Aug 3, 2012 | 12:19 PM
JoshuaW80's Avatar
Seriously? What would be the "proper toe" then?
Old Aug 3, 2012 | 01:18 PM
hologram's Avatar
0, you want it to be a dead 0
Old Aug 3, 2012 | 02:44 PM
JoshuaW80's Avatar
Thanks! And what about camber?
Old Aug 3, 2012 | 02:49 PM
VMRWheels's Avatar
I wouldn't worry about the camber as much if your toe is set.
Old Aug 3, 2012 | 02:50 PM
Mr.202?
Wrong, toe should be in the middle of the range for best tire life.
You cannot change the camber, you need to buy kits for that, if you are not lowered it should be getting into spec no problems. If it isnt something is broken or bent
Old Aug 3, 2012 | 03:03 PM
broke_as_ajoke's Avatar
yep, u need a toe bolt and front camber kit that can allow you to adjust all 3 (toe, camber and caster)
Old Aug 3, 2012 | 08:20 PM
JoshuaW80's Avatar
I see, would you recommend a camber kit or is it not that big of a problem?
Old Aug 4, 2012 | 05:36 AM
Blue Dream's Avatar
I drove ttrank's car solo
If you don't want to eat through tires I would recommend camber kits both F/R.
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
