Alignment Adjustment Hardware
Old Jan 16, 2005 | 07:59 PM
user 4560487's Avatar
Are there any other options for front camber adjustment besides the Stillen $800 arms???
Looking for something a little more wallet friendly...
Old Jan 16, 2005 | 09:58 PM
skeleton_cru's Avatar
Sedan
Do a search. There was a thread that had every option listed in detail.
Old Jan 16, 2005 | 10:02 PM
Sedan
F*ck it, I did the search for you. Go here:
https://g35driver.com/forums/showthr...ghlight=camber
Go to post #10 by Gsedan35. That's all the info you will need.
Old Jan 16, 2005 | 10:56 PM
thanks, sorry for being lazy
Old Jan 16, 2005 | 11:11 PM
Sedan
You're welcome, now drop and give me twenty you worthless maggot!
Old Jan 16, 2005 | 11:21 PM
will do, let me ask you this, I want to be able to change front camber on race day and change it back when i get home, think I can do it somewhat accurately?
Old Jan 17, 2005 | 06:42 AM
Sedan
Accurately? Probably not.
Old Jan 17, 2005 | 10:26 AM
How about drilling a hole in the right place for a reference point? Race day is easy, full negative, then when I get home, loosen up adjusters, move to my reference point, put in my reference pin, tighten up, done.
Old Jan 17, 2005 | 11:58 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Yes you can if you use a product that uses shims.
I'm using the Performance Nissan control arms which are very
easy to change for track.
Just drop out a couple of shims for your track setup.
Then put them back for street.
Old Jan 17, 2005 | 12:40 PM
cool deal on the performance Nissan arms! seems like a way to go if you plan to adjust camber *yourself* and change it often. Any downside to the shim product vs. the slide type (stillen/350evo)? How 'easy' is it to change shims out?
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
Fox843
Nov 7, 2015 05:43 PM
master111
Sep 25, 2015 08:32 PM
