Will these wheels fit? Help need asap!
Old Sep 13, 2012 | 07:42 PM
VanCity G35's Avatar
haha - true, ture. So would I even need a hub ring then?
Do you think it will work Kevin?
Thanks for the help good sir
Old Sep 13, 2012 | 09:26 PM
VMRWheels's Avatar
Ideally, yes you should run a ring - BUT you most likely won't find one in that size! If the wheels accept tapered lug nuts that in itself will center the wheel, so you probably won't see any vibrations. However, it does put additional stress on the studs, whereas your hub typically supports the weight of the vehicle and the studs/lug nuts just keep everything snug against the hub.
Old Sep 14, 2012 | 01:01 AM
Makes sense - I appreciate your knowledge Kevin.
I think I'm going to pass on them. I don't want the headache of them potentially not working 100% the way they should.
Thanks
Old Sep 14, 2012 | 12:54 PM
VMRWheels's Avatar
Old Sep 16, 2012 | 07:44 PM
Looking at Maxima wheels - please see my post here:
https://g35driver.com/forums/g35-sed...ml#post6572341
thx!
Old Sep 17, 2012 | 02:41 PM
VMRWheels's Avatar
Posted, and I'd also pass on those.
obender66
18 Inch
Mar 13, 2016 12:20 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
