wheel spacer problem
Old Sep 13, 2012 | 07:40 PM
G35_Jay8's Avatar
Originally Posted by herrschaft
Did you even look at the front spacers yet? It sounds like the lugs just came loose.
Ya im going to re-tighten them for the last time tomorrow.
Old Sep 13, 2012 | 09:30 PM
VMRWheels's Avatar
Honestly, like I said, you should remove one variable of the equation to see if that is the root of your issue. You may even be able to tell at that point if the lugs were properly seated on the spacer itself and whatnot.
Old Sep 23, 2012 | 01:30 AM
G35_Jay8's Avatar
Update:
Got the 20mm h&r wheel spacers for the front instead of the 15's..looks more flush AANNNDD the problem is solved! For now lol
Ebay=trash! Although my rear spacers are fine..
Lesson learned
Old Sep 24, 2012 | 11:37 AM
Kingdom's Avatar
I had H&R 20mm spacers on my old rsx. Replacing the studs was a pain in the ***.
So for the Z I went Ichiba 25mm both front and rear (stock suspension).
Glad to hear you learned your lesson with ebay products. Youre lucky you didnt end up with permanent damage.
Got pics!?
Old Sep 24, 2012 | 05:47 PM
G35_Jay8's Avatar
Got pics!?
I'll take pics soon!
Old Sep 26, 2012 | 12:30 AM
G35_Jay8's Avatar
Problem not solved...FML ..why make wheel spacers if they just cause problems...pissed
Old Sep 26, 2012 | 01:35 AM
4DGS's Avatar
Are these V2 style H&R spacers or slip on spacers with extended studs?
If they aren't the latter, maybe try replacing them with slip on style spacers with extended studs.
Old Sep 26, 2012 | 09:17 AM
G35_Jay8's Avatar
Old Sep 26, 2012 | 09:54 AM
G35_Jay8's Avatar
I've searched all over the internet and read about the same problem other people have..but no one knows the answer to fix this problem!
Old Sep 27, 2012 | 01:54 PM
ss284's Avatar
Originally Posted by G35_Jay8
H&R trak+ spacers are they way to go! 1k miles on my 25mm all around torqued to 80lbs on every bolt, no issues at all.
Old Sep 27, 2012 | 03:17 PM
G35_Jay8's Avatar
Lucky....is ur car lowered?
I think i just have a wheel alignment/wheel balance issue
Old Sep 27, 2012 | 04:50 PM
ss284's Avatar
Lowered an inch and a half on gf210 springs. Stock tire sizes.
Def try an alignment and have them check your wheel weights
Old Oct 15, 2012 | 02:39 PM
ㄴㅇㅇㄱ™ ninja's Avatar
Veteran: Navy
Veteran: Army
Kinetix V+,Z1UpperArms+HFC,FujitaIntake,Nismokit,BCCoils,HKSexh,G37rims,CFtrunk,nWpTB,SPCarms
I will be picking up Ichiba V2 spacers today for free, anyone have any advice for a spacer noob on revised Z springs, 17" OEM's & a busted CV boot? Can't get the axle shaft replaced for a couple weeks! Luckily it's not clicking.
Picking up from a friend, he says to buy 6 nuts, some of them are mildly stripped and have to buy 1 nut.
Came off his 09 GTR. They're 15/20mm
Old Oct 22, 2012 | 11:10 AM
G35_Jay8's Avatar
Hey guys I took off all the spacers this time and reinstalled them and my car is cured.. I think it was one of the spacers in the back that wasn't installed properly so now it rides how it's supposed to.. I also got an alignment so maybe that helped a little.. . Thanks for all the advice
Old Oct 22, 2012 | 01:57 PM
  #30
VMRWheels's Avatar
jsimonk
Dec 22, 2023 03:49 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
sailfish250
Jul 30, 2015 11:39 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
Soumilg
Jul 18, 2015 12:33 PM
