1K Budget, four 18" rims for 05 Black Sedan?
Old Jan 23, 2005 | 08:35 PM
Vsix's Avatar
Any suggestions??? I know the budget is a bit low, but I really want to change the rims... Thanks!
Old Jan 23, 2005 | 08:46 PM
Britishbloke's Avatar
I like the Moda R6 in 18". They're $249 a piece at www.tirerack.com
Yes, they're a bit heavy at 29lbs, but I quite like them, especially given your budget.
Old Jan 23, 2005 | 09:44 PM
baileyrx's Avatar
privat fahren ~225/each depending on exact size.
Old Jan 23, 2005 | 10:30 PM
Vsix's Avatar
We have an Audi A4 at home which have similar design of wheels.... any more suggestions?
Old Jan 23, 2005 | 10:55 PM
jjellyneck's Avatar
Take a look at the HP Evo. Very nice mesh wheel with deep lip for under $900 for the set.
Old Jan 24, 2005 | 01:44 AM
avs007's Avatar
How about the Kazera KZ-A I think that's $280 per wheel. I think it only comes in polished.
I also like the Work Emotion CR KAI (only weighs like 19 pounds), which is about $300 per wheel. Comes in Gold, Gun Metal, and Polished.
I also like the Ace Alloy Spyder. It actually comes in the perfect offset/size for the sedan I think. It's $228 at this store.
Old Jan 24, 2005 | 02:59 PM
Vsix's Avatar
Hey, thanks for all ur suggestions! I never knew there are so many choices in this price range!
Im now interested in Work Emotion CR KAI and Ace Alloy Spyder most
Old Jan 24, 2005 | 03:44 PM
CreativeAutoworks's Avatar
You can also look at Axis, most 18's however will run around 280.. find a set you like and email me and I'll see how i can help you out.
James
Old Jan 25, 2005 | 04:38 PM
user 4560487's Avatar
ASA AR1, 21 lbs, $229 or so i think from tirerack, 18x8 with +35 offset, i searched a lot, good price, good weight, look good, good wheel
Old Jan 25, 2005 | 04:45 PM
sen_jen's Avatar
Meatshake Enterprise
Work Emotion CR Kai would be my purchase.
Old Jan 25, 2005 | 07:12 PM
avs007's Avatar
Yeah, of all the rims discussed thus far, Work is probably the most reputable brand. (Right behind Volk/Rays from what I hear). Though they are also the most expensive of the ones discussed thus far.... Just a matter of what you're looking for I guess...
Old Jan 25, 2005 | 07:39 PM
Sukairain's Avatar
Stock G35C 18" rims..... looks very classy and large. You can get a set of $700 with tires from Ebay.
Old Jan 25, 2005 | 08:05 PM
careful there, while some have said they don't rub, some have said they do, at +30mm offset it's VERY close...
Old Jan 25, 2005 | 09:39 PM
Vsix's Avatar
interested in the Work Emotion CR KAI most... btw, thanks for all the suggestions! I was planning to get the G35c one, but kind of risky... Are there any bad things about Work wheels? some said they would bend easily...
Old Jan 25, 2005 | 09:44 PM
Vsix's Avatar
btw, these are the best pics i've found for Sedan with after market wheels.... too bad, those are PIAA and Volks, which are out of my budget...
