Brembo Opposed Piston Compression Tool
Old May 1, 2003 | 12:48 PM
tonke73's Avatar
I was planning to change the pads on my car when the time comes. I 've changed many brake pads in the past but those were floating or single pistons.
I've read up on Brembo's opposed pistons and found out that they have pistons on both sides. Let me know if this is correct.
Does anyone know where I can purchase a tool to compresss the pistons that will not damage the caliper or it's components? <P ID="edit"><FONT class="small"><EM>Edited by tonke73 on 05/01/03 01:07 PM.</EM></FONT></P>
Old May 1, 2003 | 07:39 PM
conq's Avatar
Re: Brembo Opposed Piston Compression Tool
Suprisingly you can remove the brembos pads with pliers!
Edit: woops you do need to push the pistons back in to install the new pad. Nissan recommends using a disc brake piston tool.
<P ID="edit"><FONT class="small"><EM>Edited by conq on 05/01/03 04:48 PM.</EM></FONT></P>
Old May 5, 2003 | 07:29 PM
350xfire's Avatar
There is a tool that has a flat metal piece on one side and a threaded shaft with another flat piece attached to it. When you turn the threaded shaft the plates move apart and the pistons are compressed. Check Harbor Freight Tools for this. It costs like $4 there.
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
DRG35R
Jan 31, 2016 07:14 AM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
dcsbh1
Oct 1, 2015 03:15 PM
