New Tires... 275 or 285?
Old May 21, 2013 | 11:45 AM
draco1020x's Avatar
So I'm looking to buy new tires after my last set got all burned up due to camber issues (yes I'm dropped with no kit for now) and I am debating on changing the size now. I'm running 20" axis shines which are 20x10 in the rear (offset is +20 i believe). I had a 275/30/20 tire on them before and they looked sliiiiiightly stretched. I wuz actually thinking about going with a 285/30/20 tire now to bring it further out to the lol of the wheel this time. I'm dropped about 1 1/2" on stance gr+pros and I'm a little concerned about rubbing. Does anyone know if I'll have any probs running that size tire? Or should i just stick to the 275s?
Old May 21, 2013 | 04:37 PM
shyun1250's Avatar
I would try the 285/30.
It's not a crazy meaty set up and will likely put you closer to the oem circumference.
Get a camber kit though...
Old May 21, 2013 | 06:03 PM
HenryLee's Avatar
you will be fine with 285/30/20
Old May 22, 2013 | 02:53 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
275's for sure, 285's can be a bit tight out back.
Old May 22, 2013 | 02:59 PM
gary c's Avatar
With your 20 offset on 10" rims you won't have issues with the 285s. I do suggest you get a camber kit so they wear even....Gary
lacartus
May 27, 2005 04:09 PM
NORCALSTI
Feb 21, 2005 03:49 AM
maxpower
Dec 30, 2004 09:17 AM
ColdFusion
Dec 15, 2004 01:43 AM
Meatshackle
Feb 1, 2004 02:53 AM
