Inner Tire Wear and Flipping Tire Sides
Old Aug 26, 2013 | 03:58 AM
grimpy's Avatar
I flip the front of mines as they were getting bald. Only time I wouldn't flip it is if it's so worn that you see the belts.
Old Aug 26, 2013 | 11:13 PM
xsl_will's Avatar
I autocross and as such have funky wear sometimes. Flipping definitely helps make them last. I've flipped R-comps even when I've seen cords before.
If it was for a set of wheels and tires that see daily driving, I probably wouldn't flip if it is very heavily worn. Keep an eye on it, if you catch it early, you can prolong the usefulness of the tire.
Having a tire dismounted, mounted, and rebalanced only costs around $15. I don't even bother rebalancing sometimes since the wheel is usually balanced and the tire can spin relative to the rim when autocrossing. It's a lot cheaper than shelling out for new tires when most of the tire is still good.
Old Aug 27, 2013 | 01:05 AM
gary c's Avatar
If your front tires are already making the famous roar noise it's too late to flip em! Best advice, buy new tires and get an alignment by a qualified alignment shop....that means no Sears or PepBoys but an independent alignment shop that knows how!
Gary
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
Fireman07603
Aug 9, 2015 06:00 PM
itschuckster
Jul 25, 2015 08:07 AM
realtalk21
Jul 20, 2015 09:07 AM
