BS? SPC alignment hardware
was ready to order rear camber arm and toe bolts, when noticed the below description for $90, looks like it's just the toe bolts alone, not possilble that those can ALSO adjust CAMBER???
These cams replace the OE camber and toe adjustment cams and provide additional camber & toe changes. Adjustment slots will need to be elongated using rotary files.
Note: If only camber or toe adjustments are needed, only have of this kit is needed for toe/camber adjustment. Call to order just half.
Rear Adjustment range: Camber ±3.00¡ Toe ±3.00¡
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
