19" Front 20" Rear
Old Feb 6, 2005 | 09:18 PM
Cactus's Avatar
19" Front 20" Rear
I know this has been covered here and there but I saw a Lambo Gallardo with this setup and was wondering what the point of it is? Is it all for looks? Does it help performance? I figured some of our resident gurus could shed some light on this subject.
Old Feb 6, 2005 | 09:33 PM
Squishmytomato's Avatar
If you're looking for traction, running a smaller diameter wheel in the rear would actually be beneficial.
Old Feb 8, 2005 | 09:35 PM
Cactus's Avatar
bump bump anyone?
Old Feb 8, 2005 | 09:37 PM
fastg11's Avatar
There's no way 20s would help performance, let alone 19s. 19/20 is just plain weird IMO.
Old Feb 8, 2005 | 10:43 PM
BrianlG35C's Avatar
Ohio G Club Member
Then why does Porsche, Mercedes, Lambo., etc run this setup for some their cars? If it's good for an exotic it's good for me.
Old Feb 9, 2005 | 12:12 AM
Those cars are designed for it. Going from an 18 inch wheel to a 20 inch wheel will give no tangible benefits, unless you're into loss of traction and unsprung weight.
If you like traction, running 20's in the rear is not recommended. If you're going for looks, then by all means.
Old Feb 9, 2005 | 12:38 AM
OvaYahead's Avatar
it's just like anything else. Some people do it for performance some do it for looks. It's good if you want a lot of rake towards the front and get some really low profiles on a small diameter wheel.
Old Feb 9, 2005 | 12:12 PM
Sundeviljay's Avatar
Doesn't it give the car an angle? The rear seems like it would be up a bit higher if the car had 20's in the rear and 19's in the front to give it a sportier look right??
Old Feb 9, 2005 | 01:26 PM
Cactus's Avatar
I know the Z06, Carrera GT, and a Gallardo I saw that was modified with HRE's both have +1 in the rear so I was just curious why??
Old Feb 9, 2005 | 07:27 PM
BrianlG35C's Avatar
Ohio G Club Member
So does the new Mercedes CLK AMG DTM. 19s in the front, 20s in the rear.
Old Feb 9, 2005 | 09:51 PM
Slammed's Avatar
19/20 combo is for looks only.I had way better handling with my 18 with 295 fronts and 335 rears,but the 19/20 look so cool.
Sorry for the huge pic
Old Feb 10, 2005 | 02:29 AM
TT_G35's Avatar
It would if that 20 was 10 inches wide in the rear and the 19 was 9.5 in the front. Performance maybe not, but handleing might improve a bit wearing some bigger shoes. Performance wise it will be a heavier rim and larger so yes it will slow you down a bit with the weight+extra rotational mass. Looks wise it would be SWEET! With some nice aggressive rims, maybe a 3.5-4 inch lip in the rear and 2 inch lip up front, it would look pretty dam mean.
Oh and Slammed, your car is ****en SWEEEEEEEET!
Old Feb 10, 2005 | 06:03 AM
Cactus's Avatar
Man that car is slammed!! (Hence the name) I bet that is a handfull!
Old Feb 12, 2005 | 04:48 PM
Slammed's Avatar
Thanks for comps!!!! Actually putting coilovers on it and lowering it another inch.Going to put either 19" or 20" I forged on my G35C.
Old Feb 13, 2005 | 09:04 PM
AmistadUSA's Avatar
That's jus the way it is for Lambos and Ferraris
Th611
Oct 27, 2015 03:48 PM
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
st33zygill
Jul 29, 2015 10:05 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
