steering wheel serious vibration & tire question
Old Jan 9, 2014 | 11:42 PM
Eguolo's Avatar
Originally Posted by LoSt180
Check out the Laurel BP and talk to Billy, it's on Rt 1. Many National G Club members go there and he has the proper tools to balance 20s.
And since you're in the area, check out the NGC subforum https://g35driver.com/forums/nationalgclub-133/ Hope to see you at a future meet! There's one every Thursday in Rockville.
We have a reference thread posted for local shops that might be worth browsing. https://g35driver.com/forums/nationa...nce-guide.html
Oh great info. I appreciate it, I'll definitely check it out if the problem still persists. And I've been to one meeting, I couldn't make the last one cos my girl was going off about how I'm spending more time with the G instead of her. Yeah I know, go figure. Lol
Old Jan 10, 2014 | 01:10 PM
gary c's Avatar
If she's your g/f and it's a serious relationship take her with you to meets and shows, if she has no interest find a new squeeze!
Gary
Old Jan 10, 2014 | 01:21 PM
HereKittyKitty's Avatar
Could it be a hub bearing, if there is no apparent deformation of tire. Just guessing here.
Old Jan 11, 2014 | 07:22 AM
g35SedanSC's Avatar
Bushing
Rotors-if vibrates under braking
Tie rods
Are your rims straight?
Old Jan 15, 2014 | 12:51 AM
Eguolo's Avatar
**Update Guys**
Fixed both front inner and outer tie rods, the old ones were pretty worn out and had no stability. still, the vibration still persists even after replacing these. so i'm moving on to getting new tires and going to another shop to get second opinions, this is so frustrating :'(
Old Jan 15, 2014 | 02:20 PM
coffeysm's Avatar
**Update Guys**
Pull off your tires and make sure the hubcentric ring inside isn't damaged. These can cause vibration issues. I had pretty much the same problem as you did and I replaced most of my suspension, rotors, and calipers (for other reasonts). The hubcentric rings ended up being the main culprit (my aftermarket rims didn't have them). The car would drive fine after putting the wheel back on, but eventually the vibrations came back. Ever since I put the rings on this issue has disappeared completely unless I'm at WOT I get a slight vibration.
Old Jan 15, 2014 | 02:54 PM
Eguolo's Avatar
Yeah so i've been told. i'm about to buy new tires and get alignment. i'll also check the hub ring thing too. thanks
Old Oct 27, 2014 | 08:28 PM
hyp3r3x's Avatar
Did you ever solve this problem? I have the same issue and have taken many of the same steps as you have and it still persists.
Thanks,
Matt
Old Oct 28, 2014 | 04:16 PM
VQ Johnny's Avatar
Check your tie rod ends, lower ball joints, compression rods, and wheel bearings all of which can cause vibrations along with the other suggestions above
Luisgalvan33
Jul 19, 2018 08:16 PM
kd03g99
Jul 30, 2015 11:24 AM
Luisgalvan33
Jul 28, 2015 05:37 PM
rping
Jul 26, 2015 09:53 PM
Karnicle
Jul 23, 2015 05:08 AM
