2 directional - 2 non-directional tires
Old Apr 1, 2014 | 10:24 AM
nissin67's Avatar
I just got two new fronts on my 6mt and they are non-directional. But my rears (larger size tires) are directional.
Is this okay? Because the car will rumble slightly and the tires make a lot of noise in the lower speed range.
Anyone have this set up and have this problem too?
Old Apr 2, 2014 | 02:34 PM
bchalks's Avatar
As long as the two fronts are the same size and the two rears are the same size (and installed/rolling in the right direction) you should be fine
Old Apr 3, 2014 | 07:55 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
The mixed tread designs (assuming non matched brands/models also) could cause an upset or imbalance in handling from front to rear. Probability of issues would go up in poor weather such as rain. Only a couple tire models out there are specifically designed with dir/asym mixing, the vast majority are not.
bTanz
Oct 15, 2015 02:31 PM
Karnicle
Jul 23, 2015 05:08 AM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
