Yet another wheel/tire question...
Old Jul 26, 2014 | 06:51 PM
mbavery's Avatar
Hey everyone, looking for some quick advice on sizing.
I've got a set-up in mind with the tires being F: 255/35/20 R: 285/30/20 and the rims being F: 20x8.5 +35 and R: 20x10 +35 for my 2005 coupe.
Based on a tire calculator I used, the fronts will be 20mm closer to the suspension and 10mm closer to the fender, while the rears will be 22mm closer to the suspension and 18mm closer to the fender compared to the stock 19".
I don't have my car right now so I can't directly measure it. Will this require any mods? My car is not currently lowered. Thanks!
Old Jul 28, 2014 | 05:56 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Seems a bit wider than normal. We typically run a 245/30-20 front and 275/30-20 rear with similar offsets and are okay.
Old Jul 28, 2014 | 07:27 PM
mbavery's Avatar
Thanks for the info! In terms of getting the tires flush, would you typically need to add a spacer with that configuration?
Old Aug 1, 2014 | 11:31 AM
Blue Dream's Avatar
I drove ttrank's car solo
Yes, your offsets will have the wheels sunken in. Most people shoot for around +10-15 to get the rims somewhat even with the fenders. Might even have to go lower for the 8.5" fronts to even out.
DRG35R
Jan 31, 2016 07:14 AM
BlueBelleG35x
Jul 23, 2015 02:10 PM
ScapGF
Nov 27, 2006 09:10 PM
Bluestreak
Jun 19, 2004 09:27 AM
THX723
Apr 9, 2004 03:09 AM
