bought rims, they don't fit, please help!!!
Old Sep 15, 2014 | 07:57 PM
reeseman44's Avatar
Just spent a large sum of money on 20x10" maas modular 2pc rims. They are an offset of 32mm. The fronts will not fit! They rub the inside suspension parts. So I'm gonna need a spacer im thinking. (Obviously lol) but idk if itll rub my fenders. The cars completely stock. can anyone tell me what I gotta do to make these rims fit? And if I can, what size tires will fit? I already have 295/30/20s for the back, and in thinking of getting 245/30/20s for the front. I'm hoping I don't have to roll my fenders. I'm sorry if this has been covered before, I'm in panic mode lol. Please help! And of possible post pics if you've fit these size rims with advice of how to do so. Thank you!
Old Sep 15, 2014 | 08:52 PM
PLENUMCOUPE's Avatar
U left out the most important thing we need to know, the width of your fronts. Either way, spacers and 245/35s will be ur best bet
Old Sep 15, 2014 | 09:06 PM
reeseman44's Avatar
Sorry, my auto correct edited it. They are 10" wide all the way around.
Old Sep 15, 2014 | 09:11 PM
Oh ya you'll be fine with the setup I told u. Try for 25 mm spacers
Old Sep 15, 2014 | 09:17 PM
reeseman44's Avatar
Ok awesome. I actually figured 25 mm is what I'd need since the stock is 7.5" wide and these are 10" wide and each inch is 25.4mm, and given these are a very close to stock offset that would equal each side sticking out 43.75mm. And given that I have 20x8.5" rims on there now, I know there's and inch of play to work with on the inside. So I figured 43.7 mm minus one inch (apprx 25mm) would be a good fit for a one inch or apprx 25mm spacer. Good thing I'm a machinist and can make this at work tm . Thank you for easing my mind with a second opinion. I just waneed to make sure, and didn't know if I'd get some fender run with 245/35/20s
Old Sep 15, 2014 | 09:34 PM
245s on a 10.5 will be very stretched but it's ur only shot at making it fit
Old Sep 15, 2014 | 10:01 PM
reeseman44's Avatar
10", not 10.5" so that gives me an even better chance hopefully
Old Sep 15, 2014 | 11:32 PM
BowWizzel's Avatar
If your at stock height adding 25mm spacers will have your car looking kinda weird. I'd go with the smallest spacer needed to make em fit.
Old Sep 16, 2014 | 12:29 PM
reeseman44's Avatar
I bought the 25mm spacers. If they need to be machined down I can do that at work. Anyone got pics of setups like this?
Old Sep 16, 2014 | 01:45 PM
Texasscout's Avatar
I'm in to see if you can make it work.
Old Sep 20, 2014 | 09:42 PM
reeseman44's Avatar
255/30/20 up front with 25mm spacers...clear with almost an inch clearance. The backs areally 285/30/20. I'm gonna put spacers on the back to match the Lil bit the front sticks out past the fenders. But I'm pumped there's no rub At all!
Old Jan 31, 2015 | 10:14 AM
THE MUFFIN MAN's Avatar
can I see pics of this car and set up please???
vitamin.v
Nov 7, 2019 06:10 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
BlackGee35
Jul 31, 2015 11:04 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
