Will an alignment fix static camber?
Old Sep 17, 2014 | 01:47 AM
Kicknshift's Avatar
So I lowered my car on coilovers and my rears are cambered pretty well and it looks really good but the fronts are cambered aswell (I think it looks funky)
I still haven't gotten an alignment because I've been adjusting my coilovers like crazy to get it just the way I like it.
Will an alignment make wheel even again.
The fronts don't need to be cambered because the rim will not hit the fender wall but the rears do.
Old Sep 17, 2014 | 02:45 AM
BowWizzel's Avatar
You need camber arms if still stock for adjustment.
Old Sep 17, 2014 | 02:59 AM
thegreatkwijibo's Avatar
^this, but make sure you find a shop that knows what they are doing. Your average NTB/Firestone will get your toe close, and tell you the camber is f***ed because they don't know about the aftermarket parts.
Old Sep 17, 2014 | 03:40 AM
ScraggleRock's Avatar
I don't think there's enough understanding of the terms you're using here. I'll try to explain as simply as possible.
Theoretically you want your camber at 0 if you want your tires to wear evenly. Gravity and physics make this almost impossible to dial that in as far as "still" numbers are concernered. Let me start by saying this: you need a camber kit regardless of what anyone else has told you. Our Cars suspension sucks.
That being said , have you ever seen an under inflated tire start to roll? As it gains speed it starts to grow taller due to centrifugal force. All the energy gathers around the rolling ends. Like when you used to impress your friends by swinging a bucket in a loop and the **** inside doesn't fall out. Get me?
OK, so in the same vain your suspension geometry wants to shift as it starts to centrifugally follow the laws of physics. By that I mean that it will shove all energy ever outward. When it comes to alignments and your wheel being connected to an axle, that energy wants to throw itself outward as well as upward and thats what static camber is. Basically, you want to undercompensate your camber so that when that energy is being forced to the edges at freeway speeds, it actually makes your wheels roll the way they're supposed to (flat).
So, knowing that energy will be thrown outward (up, sideways or a combination), you have to guess where it will end up at 55mph by where you set it when it was standing still. Its an art, not necessarily a science.
Here's the fun part: it depends on how low you are. I've got mine dialed in pretty well. I'm lowered 1" and have -.08 degrees camber. By the time I reach Fwy speeds, due to my center of gravity and centrifugal force throwing my wheel's energy outward, I end up somewhere near 0 when going 55mph.
Old Sep 17, 2014 | 03:52 AM
BowWizzel's Avatar
^ The length of that post leads me to believe its legit info.
Old Sep 17, 2014 | 03:54 AM
Hahahahah
Old Sep 17, 2014 | 04:14 AM
the suspensions on our cars are actually pretty awesome, but designed to handle great in stock form. as usual performance and practicality don't really coexist. my advice would be to set it to the stock alignment, but if you are really interested in how the camber affects the car read this:
http://www.motoiq.com/MagazineArticl...ve-camber.aspx
Old Sep 17, 2014 | 04:24 AM
Nah, it sucks. That's why our bushings and ball joints always go prematurely. Its tuned way too aggressively for having no adjustability. There are people trying to start class action lawsuits against Nissan for it actually.
Old Sep 17, 2014 | 10:20 AM
again not practical, but quite fun. pretty sure that was the intent.
Old Sep 17, 2014 | 12:24 PM
To be tunes to where it breaks parts? That seems counter productive. These are problems on altimas, Z, G, and gtrs. I think they just screwed up. My car handles a hundred times better with the alignment fixed than it did in stock form.
Old Sep 17, 2014 | 04:50 PM
Frankieg35's Avatar
And his use of big words, I'm sold!!
Old Sep 17, 2014 | 08:06 PM
Kicknshift's Avatar
Okay thanks for clearing things up.
So as of now I gotta throw another couple hundred for a camber kit :/
Old Sep 17, 2014 | 09:22 PM
Get the kinetix front arms. Half the price of SPC/SPL and more adjustment.
jilljann1
Jul 21, 2020 08:12 AM
Mhacker
Sep 12, 2015 07:35 PM
migurus
Sep 5, 2015 09:39 PM
jsimonk
Steering & Suspension
Sep 2, 2015 03:07 PM
