Help with aftermarket wheels&lug nut
Old Oct 2, 2014 | 01:48 AM
AJ/g35s's Avatar
Help out w/best of u could
So I bought a used Piaa wheels and they have very small gap btw the center hub which they keep telling me I have to buy a spacer but the wheels are fits fine and I have no problem ..do I really have to buy a spacer so they do fall off my car ?
Other question what's the best extended lug nut I can buy cuz I have the light weight ones but I'm afraid to put them on so I'm trying to buy a different set plzzz help out with the best u could Thanks
Old Oct 2, 2014 | 06:15 AM
Urbanengineer's Avatar
On the barrel or backside of the wheel will be some measurements. You are looking for something like 5x114mm or 5x4.5" for bolt pattern, stud size 12x1.25, hub bore size 66.1mm. If you have a larger bore wrote on the back of there, you need a HUB spacer which literally expands the hub size.
This should help
Old Oct 2, 2014 | 12:47 PM
RedHot6mt's Avatar
^^^ He is correct. For example The Hub bore on Volks is usually 73.1 bit our hubs are 66.1. This would cause the wheel to not fit properly and possibly cause vibration. Search for "hubcentric spacers" on eBay or online. The Gs wheel ore is 66.1. You will need to find out the wheelbore of your PIAAs. You'll want a 66.1 inside diameter and the outside diameter (OD) will be the size PIAA wheelbore.
Old Oct 11, 2014 | 07:15 PM
AJ/g35s's Avatar
Thanks guys , I'll try to look on the wheel measurement .. I have concerning about the aluminum light weight wheel lug nut ... I'm bought set but they are too light and I'm afraid to put them on I don't need my wheel to fly off !!! Do u guys know anything about them ??
jeffbdye
Jun 1, 2018 03:51 PM
Fox843
Nov 7, 2015 05:43 PM
NyCrAzY
Oct 1, 2015 09:19 AM
Learned Hand
Oct 1, 2015 09:02 AM
