help from tire experts on 19" sedan tires
I have an 03 g35 sedan and just bought a set of MIRO 112 19X8.5 35 offset and 19x9.5 40 offset. I will be lowered on h&r 350z springs and my fenders will be rolled. I like wide tire look, but don't mind a little stretch. just don't want to rub. everyone says different things and I have never seen these wheels on a sedan before. help greatly appreciated
What size you go with depends on a lot of factors including what camber settings do you want, how much did the springs drop you, are you willing to run spacers (current offsets will be fairly sunken in), and what look do you want (meaty, standard, stretched etc.).
When I was running the OEM coupe rays I ran a 225/40/19F and 245/40/19 rear and was happy with the look and ride. I can tell you that you're going to need front and rear camber kits or you will eat through tires quickly.
19 oem rays
I have 03 sedan with 1" eibach drop kit,also have a set of own 19" rays
225-40-19 on front ,I want to know what would be good tire size on rear
So I don't rub..I will roll the fenders if I have to and I have SPC camber kits,
Any help would be appreciated
FS[Canada]: 16" Ronal Rims with 205 65R16 Michelin X-Ice
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
