Guys that installed their own springs, step in
Old Feb 16, 2005 | 11:14 PM
DaveB's Avatar
Just curious as to how you got the top strut nut off the front struts when swapping the springs. This is assuming you don't have air tools at your disposal.
Old Feb 17, 2005 | 12:53 AM
LivyathanZero's Avatar
I'm no help here then. I did all my work in the shop at the dealer where I work. you maybe want to try and wrench on the nut and a small wrench on the shaft end. if i remember right, it's flat on two sides.
Old Feb 17, 2005 | 01:17 AM
jdbinspired's Avatar
I just used a deep socket and a regular rachet... Loosen the nut before out take the suspension of the car... It's a lot easier...
Old Feb 17, 2005 | 01:28 AM
Import-Tooner's Avatar
I had air tools. So I'm out.
Old Feb 17, 2005 | 02:45 AM
kenchan's Avatar
As jdbinspired said. Use a deep socket(19mm?) to crack loose the nut while the
strut is still on the car. Don't loosen it too much as it will just make it harder to
remove from the car.
then you use a box wrench like this...
Old Feb 17, 2005 | 12:00 PM
b0hr's Avatar
I read somewhere to clamp a locking wrench to the strut and then pin it against the ground and they try and loosen the nut. Worked on my friend's i30 strut assembly. I just torque wrenched the crap out of it till it loosened
Old Feb 17, 2005 | 12:14 PM
sen_jen's Avatar
Meatshake Enterprise
word. easiest method. i used old school gear wrench's!
Old Feb 17, 2005 | 01:41 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Originally Posted by b0hr
.... I just torque wrenched the crap out of it till it loosened
This is not recommended for a torque wrench.....
At the very least you will change the calibration,
and quite likey damage the wrench as well.
Old Feb 17, 2005 | 05:34 PM
DaveB's Avatar
That's the tool I need to get. The issue with using just a socket is that the strut shaft will often rotate has you're trying to break the nut loose. That type of box wrench will allow me to get around the recessed nut while using vise grips on the top "ear" of the strut to keep it from turning while applying torque.
I've removed/installed lots of suspensions and those top strut nuts are always a pain. Thanks for posting the pics of the box wrench.
Old Feb 17, 2005 | 05:59 PM
beangrower's Avatar
yup, i had to buy that tool last minute from checkers. they didn't have metric so i had to buy standard. oh well, it still worked...
Old Feb 17, 2005 | 07:39 PM
kenchan's Avatar
No prob. btw, there are ones with built in ratchet...those are very convenient, but I was too cheap to buy the box wrench and the ratchet ones just for the install. hehe.
Mry
Mar 3, 2023 01:03 AM
bTanz
Oct 15, 2015 02:31 PM
EPG35
Aug 16, 2015 04:52 PM
