wheel fitment help!
Old May 11, 2015 | 08:47 PM
006's Avatar
006
Question wheel fitment help!
I have a stock 06 g35 sport coupe
I want to get xxr 530 19x8.75+15 front and 19x10.75+15 rear.
with 245/40r19 and 295/35r19 tires
will these clear factory suspension? will my fenders need to be rolled?
any help is appreciated.
Old May 11, 2015 | 09:20 PM
Lartytiejdke3's Avatar
Front no with a normal sorta flush drop
Rear- my best guess is yeah you'll need to roll the rears
Clearing BBK (if you're interested) depends on disk size-not offset I'd recommend staying far away from XXR. Your stock rays are a much better wheel.
Old May 11, 2015 | 09:21 PM
006's Avatar
006
bought the car used only came with 17 inch 7inch wide msr wheels
Old May 11, 2015 | 09:26 PM
VenomGT9's Avatar
Just go in the marketplace to find some OEM Rays, way better purchase and worth the money. Most will come with tires too.
006's Avatar
006
will the rears clear the struts?
will wheel spacers make the front clear?
Old May 11, 2015 | 09:38 PM
Yes
You will clear everything fine without spacers
What you won't have is good fitment up front
Specs are too weak
Old May 11, 2015 | 09:39 PM
Very good advice
If the op plans to drop AT least $1500 (shipped+tires etc), a few hundred more can get him someone used Volk setup.
Old May 11, 2015 | 09:40 PM
006's Avatar
006
but that could be fixed with a spacer couldn't it?
Old May 11, 2015 | 09:41 PM
006's Avatar
006
problem is im Canadian so add another 30% after exchange rates
Old May 11, 2015 | 09:59 PM
It could be fixed with a spacer but do you have an option to go wider up front? And keep the same offset?
The way i see if you're so close to having enough to get a real setup. I know I'm glad I waited and got what I really wanted. You will be too once you save enough
But yeah, try to go wider up front
Old May 12, 2015 | 06:47 AM
006 here you go Almost the exact same specs you wanted with the XXRs but with tires
On my350
Old May 12, 2015 | 06:48 AM
Frankieg35's Avatar
Dont listen to Jersey he gets his fitment help from bic boys
Old May 12, 2015 | 06:49 AM
you'd have double nismo if you got that lol
That's a lot of JDM lol
Old May 12, 2015 | 10:10 AM
VenomGT9's Avatar
What forum did you pull that from?
Old May 12, 2015 | 10:49 AM
My350
It does say it on my post but it got hidden between the two pics lol
