Tein FLEX/CS - Possible to do without EDFC?
Old Feb 19, 2005 | 07:24 PM
Sukairain's Avatar
I was just wondering, is it possible to adjust the rear damper without taking the whole rear deck apart? (if you don' have EDFC) The front suspension can be adjusted from the engine compartment easily, but the rears are hidden under the deck.
I am very much into the EDFC function, but $300 Cost + $500 installation makes the EDFC the same price as a Tein Basic setup. [I was quoted $150 to install the coil over alone, but aounrd 500 more to install the EDFC unit] Is it possible to drill a little hole somewhere near the rear structs and use one of those flexi-wrench extender type tool to make it possible to adjust rear damper without having to take body panels off?
Old Feb 19, 2005 | 09:31 PM
R2 V35's Avatar
Life is a lot easier with the EDFC. I got mine installed for $450, got it done @ Dynamics in Lake Forest. You can also check out Super Autobacs in Stanton, they did my friend's Z and my bro-in-law's sedan for the same price. Both place did an excellent job. Goodluck!
Old Feb 20, 2005 | 05:44 AM
beangrower's Avatar
i thought the cs wasn't edfc compatible??
Old Feb 20, 2005 | 06:28 PM
kenchan's Avatar
cs is compatible. But Im not sure if it's worth installing unless you're going to
track the car and you need to change settings frequently between street and
track. It does seem like a fun toy to have though...
If I was doing it, I would just play around with the dampness until I get the
ideal setup.
Old Feb 21, 2005 | 07:54 AM
beangrower's Avatar
ideal setup.
okay, just checked the catalog. it is compatible but it has a note *7 which states "space is not enough". what's that about. this is off the '05 catalog.
do you need to modify it?
Old Feb 21, 2005 | 12:35 PM
Premier's Avatar
no problem here on my 04
KruZZe
Feb 27, 2023 05:04 PM
nissandrifter32
Dec 22, 2015 04:28 PM
bigmike
Sep 17, 2015 01:58 PM
