Rim spacer question?? What is it exactly?
Old Feb 25, 2005 | 04:54 PM
NORCALSTI's Avatar
ok i know it pushes the rims out. like the rims im looking at they say you need a 5mm spacer to push the rim out so it clears the brembo brakes. so does that mean the spacer is only like less than a 1/4 inch in width cause 5mm equals about .20 so closest thing would be a 1/4 inch spacer correct. so you just put the 1/4 inch thick spacer behind the wheel and it pushes the wheel out 1/4 inch so it will clear the brembos. am i missing something here or am i on the right track?
Old Feb 25, 2005 | 05:13 PM
jedmonds's Avatar
You are on track, but dont just buy some cheap a$$ spacers. Get the H&R wheel spacers. I tried some cheap a$$ ones from a local tire shop and at high speeds there was way too much vibration in the wheels. The H&R's are made of much better quality. And when I installed them I didnt notice a difference in ride quality with the H&R's and without them.
Old Feb 25, 2005 | 05:59 PM
dklau33's Avatar
You can get H&R spacers from here.
http://www.optauto.com/index.htm?par...7&deptid=12539
And oh yeah, it's not rims, it's wheels.
Old Feb 25, 2005 | 06:39 PM
CrazyMike's Avatar
I used a 3 mm spacer to put 17" coupe rims on my 6mt. Worked great for winter wheels/tires and I never had any vibration. I woudn't get anything thicker than 3mm though unless you replaced the studs. I think Nismo might make a nice one spacer that goes out a little farther...
Old Feb 25, 2005 | 07:26 PM
NORCALSTI's Avatar
ISNt the 5 mm spacer just pushes out less than a 1/4 of a inch?? it looks like there is more stud left than just using 1/4 of it less. i mean 1/4 less and still will be safe
jsimonk
Dec 22, 2023 03:49 PM
vitamin.v
Nov 7, 2019 06:10 PM
Gip
Aug 24, 2015 05:31 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
