Which Spacers Do I Need
Old Aug 11, 2016 | 01:05 AM
NathanielV35's Avatar
I'm new to suspension on cars. I just lowered my G35 coupe on Eibach Pro kit. 1.1" front 1.0" rear. Im wondering which spacers would fit with no issues. I just got new tires not too long ago so I cant get wider tires.
Old Aug 11, 2016 | 02:19 AM
ScraggleRock's Avatar
What wheels do you have?
Old Aug 11, 2016 | 09:47 AM
Lartytiejdke3's Avatar
doesn't matter. as long as his wheels are round any spacer will work.
Old Aug 11, 2016 | 11:05 AM
I have a 2004 Sports with 18s. I dont know which size to get. Like i said its lowered on eibachs pro kit. I dont wanna roll my fenders but would like to know what mm spacers i can get with out rubbing but be flush.
Old Aug 11, 2016 | 11:23 AM
measure the difference between the tire and the fender in mm's
buy the spacer accordingly.
pretty simple.
Old Aug 11, 2016 | 09:03 PM
saywat?'s Avatar
search man
Old Aug 11, 2016 | 10:16 PM
You need 25mm spacers, but will need to roll your fenders. You can do 20mm and not roll, but then your grandma will call you a lame b!tch.
Old Aug 15, 2016 | 02:53 AM
Blue Dream's Avatar
I drove ttrank's car solo
I nearly spit up on my laptop when I read this. Well done JT!
Old Aug 24, 2016 | 10:30 AM
driftsucky's Avatar
Old Aug 24, 2016 | 11:13 AM
Texasscout's Avatar
pretty simple.
WHS (What He Said for the benefit of newbs), It all depend on how wide your wheel is. On my sedan, I had 8" wide wheels with a +30 offset and it was just perfect. I had some M35 (+45) wheels for a while and I had to run 5mm spacers in front just to clear the brake calipers. I didn't want to run a bolt on spacer, I just don't trust them. A coupe has a different offset so it is a bit different.
Old Aug 24, 2016 | 11:27 AM
deeliciousqueen's Avatar
G35 coupe 6mt
LMAO! that was good!
I ran 25-20mm on my stock 19's with 1.5 drop. I'm happy with it. I found out through searching the forum.
silversleeper
Steering & Suspension
11
Aug 23, 2016 02:05 PM
nicoG35
Feb 26, 2016 04:55 PM
nicoG35
Feb 22, 2016 10:20 AM
Blk_G35
Jan 15, 2003 07:17 PM
Msedanman
Nov 21, 2002 11:06 PM
