Rim and brake question 05 coupe
Old Mar 9, 2005 | 09:19 AM
Infinitz's Avatar
With my new 05 coupe on its way I was wondering if I am going to need spacers with my 20 inch Axis Mod 7 Rims. The front rim has a 37 offset. I know the front brake isnt as large as the brembo but I am not 100% sure. Can anyone help ????
Old Mar 9, 2005 | 09:39 AM
Wingsprint's Avatar
How wide are the wheels?
38mm is about as low as you can go without the wheel/tire sticking out beyond the fender.
Old Mar 9, 2005 | 09:50 AM
Wingsprint's Avatar
Oh..
To give you an idea these are my 18x8.5 wheels with a 45mm offset on an 05 Sedan. My wheels have 8mm more clearance than a 37mm offset and they look very flush with the fenders.
You will 100% not need spacers!
https://g35driver.com/forums/attachm...tid=6808&stc=1
Old Mar 9, 2005 | 09:58 AM
Infinitz's Avatar
they are 9.0 in the front
Old Mar 9, 2005 | 10:34 AM
paranormal's Avatar
well if this helps check my sig thats what i have on order.. 20x8.5 in the front and 20x10 in the rear.
Old Mar 9, 2005 | 01:05 PM
Wingsprint's Avatar
With a 37mm offset?
That would stick out 14mm (or just over a half an inch) further than my wheels, and they are very close to being flush with the fenders.
I think you need to look for a higher offset to look right on the sedan using 9" wide fronts. Most likely a 45mm to 50mm.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
kinetek
Aug 3, 2015 04:25 PM
vstypicals
Jul 20, 2015 10:55 PM
mushu
Jul 15, 2015 03:55 PM
EasySausage
Jul 14, 2015 11:17 PM
