Wheel Balancing?
Old Mar 10, 2005 | 12:59 PM
desertG's Avatar
Wheel Balancing?
I recently bought a used 03.5 sedan and put a set of Foose Speedster 20"s on it. Since I put on new wheels and tires, I've been feeling some vibration at around 65 mph. With the stock wheels, it rode smooth as glass. I can't tell if its a wheel balancing issue, or if there is just more "road feel" due to the bigger wheels/low profile tires.
Any thoughts?
Old Mar 10, 2005 | 01:00 PM
kenchan's Avatar
Your wheels/tires probably need to be re-balanced.
Are those hubcentric wheels?
Old Mar 10, 2005 | 02:03 PM
desertG's Avatar
sorry, I don't know what "hubcentric" means.
Old Mar 10, 2005 | 05:42 PM
TimW's Avatar
if you look at your rotor, you'll see a ring around the axle nut. The OEM wheels actually use that ridge to center the wheel, not the lugs. Aftermarket wheels need rings because the center is large to accomodate various makes of cars, and lug holes alone are not enough to center the wheel properly. Perferrably metal rings.
If you have hubcentrics, find a Hunter Roadforce balancer in your area.
http://www.gsp9700.com
enter your zip code.
This machine uses a roller to simulate the road and will find out of round tires or sidewall issues. Even radial pull on the new models.
andyg35c1
Aug 29, 2015 03:37 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
MyfistYourFace
Aug 8, 2015 11:58 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
