Had to lock up the brakes today.. my brakes squeak again
Old Mar 16, 2005 | 03:08 PM
IS300TOG35's Avatar
► Matt ◄
Angry Had to lock up the brakes today.. my brakes squeak again
I went out for a spirited drive today after installing my k&n drop in and my motordyne spacer. Anyways to make a long story short I was on a road I wasnt very fimiliar with, goin about 60 mph. In a spilt second I realized where I was (coming up to an intersection and didnt realize becuase someone hit the stop sign and it was poiting toward the sky.) So without even thinking I locked up the brakes coming to a really hard stop (definately the hardest Ive ever hit the brakes) and was about 5 feet into the intersection. (no cars were coming, thank the lord) Well it scared the Shi* out of me so I took it easy on the way home but now I'm experiencing the squeal I used to hear when the car was new when I'm almost to a full stop I got 16k on my stock pads + rotors and Im hoping I dont have to replace them but does anyone know if locking up the brakes hard just that once will lead to them needing to be replaced? I was having a blast with my new mods and that wasnt the best way I wanted to end my spirited drive. Any brake gurus please shed some light.
Old Mar 16, 2005 | 06:53 PM
sherwooa's Avatar
No, you probably just glazed the pads a bit. Try re-bedding them as per the procedure in the FAQ. If that doesn't work, you may need to pull out the pads, scuff them a bit with some sandpaper, and then put them back. Then re-bed them.
Old Mar 16, 2005 | 10:44 PM
kenchan's Avatar
you didn't actually lock them up, right? You had the ABS turned on?
Old Mar 17, 2005 | 10:56 AM
IS300TOG35's Avatar
► Matt ◄
yea abs definately went on but i had the pedal to the floor fighting the abs the entire time.
Old Mar 17, 2005 | 11:36 AM
kenchan's Avatar
I think you're fine. a couple of 60mph- 0 isn't going to kill the brembos.
G35-R
Nov 7, 2015 01:21 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
douglas555
Sep 10, 2015 04:48 PM
johnadlertech
Accessories
Sep 8, 2015 11:57 AM
