245/40/18 front and 245/45/18 rear?
I am doing this setup on my G coupe, I was wondering if anyone else has this setup and have any problems with it? I went to the dealer today and they kept on saying this setup will throw off the VDC and I think they're full of crap. Anyone can confirm? Thanks.
not sure how to calculate stagger, but as comparison:
factory stagger 2.66% (rear vs front)
your stagger 3.62%
I think you are plenty fine... my current stagger on 19's
3.11% (245/35/19, 275/35/19). absolutely no issues.
your stagger 3.62%
Depending on brand - The stagger should remain exactly the same. Doing straight math may show slightly different results, but in the real world using tire manufacturers specs., the 245/40/18 has the same OD as the 225/45/18. The only change you will notice will be less understeer due to the wider tires in front. The car will be more neutral. You could also put 255/45/18 in the back. VDC will not be affected.
Good Luck
Lou
Good Luck
Lou
I had 255's on the rear of my coupe for over a year. Pilot sports. Good fit & grip.
NOW, before i get flamed, don't bother, I don't care.
I'm am also not reccommending this to anyone else,
it's just what I have.
I currently have: (stock 17x8in rims all the way around)
Goodyear Eagle F1 Supercar 275/40/ r17 on the rear
Michelin Pilot Sports ..........255/45 f17 on the front
Super grip, nice predictable ride
FYI
FYI
bailey,
how does a 275 tire look on a 17'' rim?? I have a 19x10 inch rim in the back w/ a 285 tire...just curious how it works...
btw, any specific reason as to why your running iridium plugs?? if i recall you did have the small 'NOS' bottles you had bought from ebay...is that the reason your running those plugs?
I recently "upgraded" to a sneaky pete nos. 50hp shot
I use the small bottles on the weekend(hahha)
I'll post pics of my wheels & nos whem I have the time.(soon)
as not to take over this thread,
