Is this rear camber ok?
Old Mar 23, 2005 | 02:21 PM
IS300TOG35's Avatar
► Matt ◄
I got my Tein 350z H-techs installed today. My camber in the rear is a little out -2.08 (spec he said is -2.04) I let him do the alignment today, but I'm going back 2 weeks from now to check it out after they settle a bit. Is my camber really out of spec? Do I need camber arms? Or will they be able to go back into spec when they settle?
Oh, and he said that my right outer toe rod was worn out and to call infiniti becuase it should be under warranty. I called and made and appt and the guy said they will replace both sides. Has anyone's outer toe arms worn out on them, and what causes it? Thanks!
Old Mar 23, 2005 | 07:51 PM
IS300TOG35's Avatar
► Matt ◄
Old Mar 23, 2005 | 09:57 PM
kenchan's Avatar
wow, you got measurements down to the one hundredths?
-2 sounds good. Give it a good 4-5 weeks before going back.
What's your front at?
outer toe rod worn out, huh? hummmmmm...haven't heard of that one.
Old Mar 23, 2005 | 10:29 PM
IS300TOG35's Avatar
► Matt ◄
He didnt mention the front at all so I'm sure that its in spec. Ill get a full print out in a couple weeks when they look at it again.
and dont scare me with the outer toe rod thing.
Old Mar 23, 2005 | 10:46 PM
turbomaxima's Avatar
Man with green rock in Vortech
well the factory has some adjustment for camber in the rear.. and most drop-springs arent going to drop it far enough to where the settings cant be adjusted so that it is close to spec. if anything, just buy the spc toe bolts and camber arms if you need to rid yourself of more camber in the rear, but you should be fine. tires may wear a little faster than normal, but nothing noticable.
Old Mar 24, 2005 | 12:19 AM
kenchan's Avatar
eibach prokit. it'll easily take you out of the factory adjustment range.
so does most springs that lower 1" or more.
linedr89
Aug 17, 2015 05:11 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
nascarbuff17
Jul 16, 2015 10:23 AM
