350z Tein H Techs installed. Pics and info inside<<
Old Mar 24, 2005 | 04:48 PM
NORCALSTI's Avatar
ok just overview
2003 6mt coupe
225 45 18 front tires rear tires 245 45 18
after looking at all the springs the 350z Tein H Techs were the best in my opinion. I wanted a spring that handled better and rode good and I can honelstly say the ride quality is great and car handles better.
So now for the total drop. on the 350z it says .3 in front and .2 in rear but on the g35 its more.
BEFORE I LOWERED THE CAR FROM GROUND TO FENDERLIP IT MEASURED THE FOLLOWING
FRONT LEFT AND RIGHT 27 1/8 INCHES
REAR LEFT AND RIGHT 27 3/4 INCHES
AFTER DROP FROM GROUND TO FENDERLIP
FRONT LEFT AND RIGHT 25 15/16
REAR LEFT AND RIGHT 26 7/8
So the springs gave me a final drop of about 1 1/4 in front and rear about 7/8 inches.
NOW IN REAR YOU CAN LOWER IT WITH NO CUTTING OF THE SPRINGS HERES HOW. For me the rear needs to come like 3/8-1/2 inch more down which is no problem. In back when you remove the springs you will noitce the rubber bumpstop. Now on top just cut a straight line off the bumpstop on how much lower you want the car. 1/2 inch off the top of the rubber bumpstop will lower 1/2 inch when car is dropped
Anymore questions just ask away
here are the pics
Old Mar 24, 2005 | 06:47 PM
beangrower's Avatar
hey norcalsti, in that pic, did you cut the rubber mount in the rear or is that just after you installed the springs. I was gonna cut mines but not sure if it'll even out the rear or go lower than the front. I noticed with a full tank of gas, the car is almost an even drop.
Old Mar 24, 2005 | 06:53 PM
NORCALSTI's Avatar
HAVENT tested with a full tank yet ill prob do that later today.
right now on almost empty tank rear is 3/4 of a inch about higher than the front
Old Mar 24, 2005 | 08:12 PM
g_man35's Avatar
Now, when you cut the bump stops, does the ride quality deteriorate? Also, as askded before, are those pics with the bump stops cut or not??
ChuckP's Avatar
damn, 1.25'' in the front, does eveyone experience that drop in the front with 350z h-techs? if so i am going to go with those for sure.
Old Mar 24, 2005 | 10:32 PM
WRAH's Avatar
WRAH
I can't tell you did anything. Must be the white car, mines black and looks just as low!
Old Mar 24, 2005 | 11:56 PM
NORCALSTI's Avatar
in person you can totally see. the rear drop is WITHOUT cut bumpstops. ill prob cut them next week
Old Mar 24, 2005 | 11:57 PM
NORCALSTI's Avatar
LIEK I said 25 15/16 from ground to front fenderlips which is at least a 1 inch drop
Old Mar 25, 2005 | 12:03 AM
IS300TOG35's Avatar
► Matt ◄
Before and after pic of my G dropped on Tein 350Z H-Tech springs.
Before
After
Thats the closest I have for compare at the moment, but ill look over what pics I have of my G with stock springs and take pics of the car now in the same positions.
Old Mar 25, 2005 | 12:17 AM
WRAH's Avatar
WRAH
I can see it in these pics
Old Mar 31, 2005 | 07:47 PM
chowtime's Avatar
Norcalsti, have you aligned your car yet and if so were you able to get it back to specs? Looks nice.
Old Mar 31, 2005 | 08:56 PM
anbakookie's Avatar
anybody got h-tech with 19's?? I want to see how bad the gap is before i get these springs!! Do you guys think itll be bad or good?
Old Mar 31, 2005 | 10:09 PM
IS300TOG35's Avatar
► Matt ◄
I will in about 2 weeks, Im gettin my 19s Monday!! these...
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
youngdip631
Lighting
Aug 27, 2015 03:49 PM
zcherub
Aug 27, 2015 09:47 AM
Gookiecrunch
Aug 19, 2015 12:00 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
