Tire Shake on Toyo Proxes
Old Apr 4, 2005 | 11:49 AM
Infiniti4ever's Avatar
Unhappy Tire Shake on Toyo Proxes
I recently replaced the stock Bridgestone Turanza EL42s with Toyo Proxes TPTs. I had worn down to the wear bars on the Bridgestones at 40,000 kilometers so wanted a high speed all weather tire so got the Toyos.
My question is, - has anyone else had any problems with a high speed quiver or shake at above 110 - 120 kph? ( 60 - 70 mph ) I have had the new Toyos balanced 3 times and finally replaced with new ones by the tire shop and specialty balanced but there is still a very slight twitch to the steering wheel on real smooth roads.
Has there ever been a TSB on the factory wheels or steering parts that may cause slight shake? I have the Aero and track suspension with 17" 5 spoke wheels.
Any input would be appreciated.
Glenn
Old Apr 4, 2005 | 01:14 PM
TimW's Avatar
have you had them roadforce balanced on a Hunter machine?
Old Apr 4, 2005 | 01:25 PM
protocav's Avatar
indeed...
also, you could have simply gotten a bad balance. it is not the tires.
Old Apr 4, 2005 | 01:29 PM
TimW's Avatar
also, see my post about the KDW2s. a stiff sidewall might need some WD40 to seat perfectly.
Old Apr 4, 2005 | 02:01 PM
kenchan's Avatar
it sounds like you just need it re-balanced.
If you drive on dirt roads sometimes the dirt stuck in the treads will take the
tire out of balance..typical issue with WRX people driving after dirt roads.
Old Apr 5, 2005 | 12:22 AM
BlackGSedaN1027's Avatar
I had nasty vibration on my front right tire. I have the Toyo Proxes as well. Took it to a hunter machine, and no vibration. That machine is awesome. Fixes 98% of vibration problems, or so Ive heard. You should give it a try.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
socaldavid
Sep 5, 2015 04:35 AM
