Is this alignment any good?
Old Apr 13, 2005 | 01:08 AM
Daddylongstroke's Avatar
I just got the car aligned. Running TEIN basics, Kinteix Front A-arms, SPC rear camber kit with toe bolts. Not sure how to read this but could anyone tell me if i'm back in spec? If not, whats wrong. Thanks in advance - Bobby
Camber Front Left -0.66
Camber front Right -1.21
Camber rear Left - 1.48
Canmber rear Right - 1.46
Total toe rear .21
Total toe front .33
Cross camber front 0.56
Cross caster front -.08
Thrust angle .08
Old Apr 13, 2005 | 02:11 AM
MEECHIN's Avatar
From what i know... you're within specs.
Your rears are fine...
Of the four, it seems like the Front Right is the most out of place.
However it's still under -1.25 which is the most negative factory spec.
(that's with 18s tho)
Do you roll 19s?
Old Apr 13, 2005 | 02:15 AM
im on the stock 17's for now
Old Apr 13, 2005 | 09:41 AM
G35fromPA's Avatar
Not sure what units they're using, but based on the specs below, I think your front total toe, cross camber and cross caster are off.
Specs from the Service Manual (applies to Coupe with both 17's and 18's):
FRONT:
Camber:
Min: -1.25*
Nominal: -0.50*
Max: 0.25* (* = decimal degree)
Camber L & R Difference: .75*
Total Toe:
Min: 0mm (0 in)
Nominal: 1mm (0.04 in)
Max: 2mm (0.08 in)
Caster L & R Diff: .75*
REAR:
Camber:
Min: -1.75*
Nominal: -1.25*
Max: -.75*
Total Toe:
Min: 0mm (0 in)
Nominal: 1.8mm (.11 in)
Max: 5.6mm (.22 in)
Old Apr 13, 2005 | 12:17 PM
Gsedan35's Avatar
Total toe rear .21
Total toe front .33
Thrust angle .08
You have the ability to adjust camber, why on earth would the shop push a car out the door as "finished" with that much of a differance in front camber, shame on them. Take the car back and make them set the left camber -1.2. Also, you have way too much toe, which is toe "in" I hope. In the front, have them dial the car to .02" per side (.04" total front toe in) In the rear I would have them set the rear toe in to .055 per side or .110" total. Again, make sure they are giving you toe in, not toe out. Also, make sure they keep the rear camber even side to side when they do the toe work.
Old Apr 13, 2005 | 04:41 PM
Thanks for the feedback g35sedan. I'll call them later to see whats up.
Old Apr 14, 2005 | 01:37 AM
kenchan's Avatar
Definitely too much toe-in on the front. Rear could use a little more if
coupe.
Old Apr 14, 2005 | 06:04 AM
Hey guys would the fact that my car is 1/4 inch higher on the right rear side explain the discrepancy? My coilovers are set at the same point on the rears but the right side has always been a little higher.
Old Apr 14, 2005 | 08:08 AM
G35fromPA's Avatar
No love for me, huh?
Old Apr 14, 2005 | 12:27 PM
Gsedan35's Avatar
I'm sure he appreciated your post, I for one thought your posting of the oem coupe specs was beyond what most people are willing to do, keep up that spirt.
Old Apr 14, 2005 | 04:03 PM
O my Bad! I actually printed out those specs from your post! Thanks G35fromPA! Your post was greatly appreciated.
Old Apr 14, 2005 | 04:13 PM
kenchan's Avatar
could be..
You need to put the car on a flat surface and even out the ride
height. Would be best if you can have someone to measure it
while you're in the driver seat.
If you really want to corner balance correctly, you'll need to
undo the endlinks from the swaybars, get adjustable endlinks,
match ride height, and then adjust the endlinks and tie
everything down.
Old Apr 14, 2005 | 10:26 PM
G35fromPA's Avatar
I figured...I was just bustin' chops.
Anyway, happy to do it. I've received plenty of great advice from this and other forums, so I always try to give back when I have the knowledge or ability.
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
bjo16
Aug 4, 2015 09:52 AM
itschuckster
Jul 25, 2015 08:07 AM
Soumilg
Jul 23, 2015 09:26 AM
