Adjusting rear coilovers...
Old Apr 17, 2005 | 06:33 PM
wickedG35's Avatar
Does anyone else have a hard time adjusting the height of the passenger side rear coilover? The lower portion of the gas tank is right there and doesn't allow you to give a good turn with the provided hook spanners (I have the Tein basic coilover kit). I was able to lower the rears a little more than I originally had it set to but not by much. The fronts are great and tucking tire like I want
Old Apr 17, 2005 | 10:11 PM
tig488's Avatar
i was wondering about this, i didnt know if you use the same hook spanners for the rear as you do the front, i just installed my basics and i didnt think the spanners would fit the rears.
Old Apr 18, 2005 | 12:11 PM
beangrower's Avatar
got pics? always wondered how low the tein basics can go? did you adjust the front and rear all the way down?
Old Apr 18, 2005 | 08:13 PM
wickedG35's Avatar
The front is tucking tire and looks amazing; I can go a tad lower on the front but I've already got a 1" extra drop due to the nismo lip and am already scrapping a bit up driveways so I'm going to keep it at its current height. The rear can go down a tad bit more but the stupid gas tank is preventing me from being able to turn the hook spanners!
Here's a pic taken recently:
Old Apr 25, 2005 | 11:56 PM
GQ 350z's Avatar
How low can you go in back? Could you tuck the rear if you wanted to? I'm looking for about 1.75" at least in back.
Old Apr 26, 2005 | 12:41 AM
THX723's Avatar
G Kreuzer
You can do away with the fuel line cover by undoing the snap clips. It'll buy you a little more room to work the spanner wrench.
Old Apr 26, 2005 | 12:46 AM
wickedG35's Avatar
Not with the Tein Basics. I think the lowest you can go in the rear is about 1.2" - I'm at about slightly less than an inch in the rear.
Thanks Clint! I'll give it another shot when I have free time. Right now it looks like my motor weighs 2 tons with the car angled forward a bit
Old Apr 26, 2005 | 12:57 AM
wickedG35's Avatar
removed *double post*
Old Apr 26, 2005 | 01:01 AM
GQ 350z's Avatar
Hrrm, interesting. Anyone have insight on the coilovers max drop height in back? I'm about to purchase some so any help would be great. At least 1.75 in back baby!
Old Apr 26, 2005 | 09:58 AM
G35sedan03's Avatar
I know you can do more than 1.2 drop in the rear with the Tein basics. I have them and currently have a 1.3 drop in the rear and 2 in the front. I will get on here later on tonight to post the actual max lowering for front and back.
Old Apr 26, 2005 | 12:08 PM
GQ 350z's Avatar
G35sedan03, this will be of great help to me. I'm getting these to get the right stance, I'm not hitting the auto x any time soon.
The sooner you can post the better, I have a deal pending so I can purchase a set..Thanks so much!
ravi
Old Apr 26, 2005 | 02:11 PM
Gsedan35's Avatar
Sedan's ride 1/2" higher then coupe's do, so that's why they will see a bigger drop overall on a sedan then a coupe on the same coilovers.
http://www.tein.com/infiniti.html
From Tein's spec page the max drop for Tein basics on a sedan is
3.7"/1.4"
Minimum drop for Basics on a sedan is
1.6"/0"
Again from Tein's spec page the max drop for Tein basics on a COUPE is
2.6"/1.2"
Minimum drop for Basics on a COUPE is
.7"/+.2"
The two car's do not start from the same oem right height points, so drop amounts will not be the same.
Old Apr 26, 2005 | 11:54 PM
G35sedan03's Avatar
As usual GSedan35 is right. I always depend on his input for any suspension question I ay have and that's why I recommend others to do so and use the search option for his posts which are usually very informative. Thanks again.
mjfenix
Aug 17, 2017 05:49 AM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
