Fender Rolling
Old Apr 25, 2005 | 10:26 PM
Chico's Avatar
Fender Rolling
Hi Guys...those of you that have rolled your fenders...did you experience any cracking on the paint at all?
I am getting my car lowered on Thursday and the shop doing it told me they have to roll the fenders to prevent any rubbing. I agreed with them 'cause I can see it hitting it.
However, they explained that sometimes when rolling the fenders, in some cars the paint tends to crack on the outside. Has this happened to anyone?
The other option is to cut the inner lip.
What do you guys think? Any comments from past experience is appreciated.
Thanks.
Chico
Old Apr 25, 2005 | 10:30 PM
G352NV's Avatar
Never enough
Rent a fender roller and TAKE YOUR TIME! Its pretty easy as long as you TAKE YOUR TIME and work the metal.
Old Apr 25, 2005 | 10:36 PM
Chico's Avatar
Where do you rent it from?
Old Apr 25, 2005 | 11:28 PM
hksjza70's Avatar
due to the shape of the fender rolling is not recommended
there is nothing to roll or cut in the front, and I had my rears cut, but only for peace of mind
get the correct offsets, otherwise see a seasoned professional
Old Apr 26, 2005 | 07:00 PM
Chico's Avatar
Anyone else with comments or suggestions?
Thanks.
Old Apr 27, 2005 | 03:19 PM
ROCKETDAWG's Avatar
Look under the rear fenders, the lip is approx .75 wide (and thick) in the middle area and transitions down on each side. Just remove the rear tires/rims. trim appox .38 off as follows. Mask off as required to prevent paint damage and to maintain a straight line, carefully trim (straight) by using a cut-off wheel/grinder and transition down. Touch-up bare metal using primer/enamel as required. Re-install rear tires/rims torquing to 80 ft lbs. If you do a nice job, you won't be able to tell it's modified unless you new how thick the original lip was. That's it!
Old Apr 27, 2005 | 03:43 PM
Chico's Avatar
thanks Rocketdawg...I have a shop doing it tomorrow. I'll ask how they do it first before I show them your comments. I'll post pics when done.
Thanks.
Old Apr 30, 2005 | 06:40 AM
brittain's Avatar
did you get it done? pics? price?
Old Apr 30, 2005 | 11:09 AM
Chico's Avatar
I got the car lowered, but I didn't have to roll the fenders at all. It was a perfect drop. The 20's really make a difference in closing up the gap. Here are a couple of pics.
Old May 1, 2005 | 01:43 AM
sammyG35's Avatar
what kind of drop do you have?
can you post sizes and offset of wheels\tires?
thanks!
Old May 2, 2005 | 11:43 AM
JUAN's Avatar
Yeah chico you should test the car (not drive) with people seating in the front and the back before you regret rolling the fenders, its a big difference.................
Old May 2, 2005 | 08:09 PM
Chico's Avatar
Not sure what you tried to say. Can you rephrase please?
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
DRG35R
Jan 31, 2016 07:14 AM
dcsbh1
Oct 1, 2015 03:15 PM
NyCrAzY
Oct 1, 2015 09:19 AM
