Torque when putting on Wheels
Old May 20, 2005 | 03:34 PM
wanalaugh74's Avatar
How many FT/LBS of torque should I set my torque wrench to when I put my wheels on? TIA
Old May 20, 2005 | 03:57 PM
twilightG35's Avatar
my 19s are torqued at 85lbs.
Old May 20, 2005 | 04:05 PM
myGspot's Avatar
anywhere from 80-100 ft lbs is good enough. I dont rally torque them unless i'm going to do hot laps on the track.
Old May 20, 2005 | 05:25 PM
protocav's Avatar
my 20's are torqued to 85 as well.
Old May 20, 2005 | 05:29 PM
Thx guys.
Old May 20, 2005 | 06:34 PM
tkman00's Avatar
80 is stated in the manual
Old May 20, 2005 | 06:43 PM
DaveO's Avatar
72-87 ft-lbs according to the service manual.
Old May 20, 2005 | 07:33 PM
RichK's Avatar
I check torque every month. Unevenly torqued wheels will help warp rotors. Especially if you drive the car hard and heat the brakes up.
Old May 20, 2005 | 09:33 PM
myGspot's Avatar
How is that ??? Never heard of anything like that.
Old May 21, 2005 | 02:49 PM
n1cK's Avatar
G35 6MT
if unevenly torqued, the force distribution throughout the rotor will also be uneven. as the rotor heats up and cools down, thereby expanding and contracting the rotor, the uneven distribution will eventually warp the rotor slightly. this is also the reason why you are supposed to do a star pattern when torquing down the wheels, as opposed to just going in a circular motion.
Old May 21, 2005 | 07:37 PM
kenchan's Avatar
With my street driving (although spirited driving at times) the Brembo's don't get
hot enough to the touch. Im running GT3 wheels so the cooling might be
better than factory wheels..not sure.
I use 105ft/lbs on the Tirerack's $29 torque wrench..I doubt it's really 105 though...
i think it's more like 95ft/lbs. I use to use an expensive one but it fell
off the shelf and died. but I remember how tight is was by hand
using my standard 1/2" drive. My hand tightening was usually within
5ft/lbs when I double checked with the torque wrench.
Old May 22, 2005 | 02:47 PM
skeleton_cru's Avatar
Sedan
I use 80 ft-lbs.
Old May 22, 2005 | 05:28 PM
g35doc's Avatar
80 as stated in the manual. I don't see any reason to go higher than that.
jsimonk
Dec 22, 2023 03:49 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Jadenkid22
Jul 14, 2015 12:33 AM
