Lowering w/Springs Only, Suggestion?
Old May 20, 2005 | 07:05 PM
GGGunit35's Avatar
I want to lower my ride about 1" only. Basically I want to lower my car to the max without having to deal with a camber kit. What is your recommendation? Also, how is the Tein S Tech in this situation. Thanx in advance.
Old May 20, 2005 | 07:27 PM
G352NV's Avatar
Never enough
I have a set of Tein H techs that will work perfect, 125.00 shipped.
Old May 20, 2005 | 08:26 PM
GGGunit35's Avatar
whats the drop amount?
Old May 20, 2005 | 08:42 PM
GReddySetGO's Avatar
What kinda rims do you have?
I have Tein S. Techs as well as a bunch of other locals, they're a good spring and a good price.
Old May 20, 2005 | 09:23 PM
GGGunit35's Avatar
Car is stock 05
Old May 25, 2005 | 03:08 PM
GGGunit35's Avatar
Any other help?
Old May 25, 2005 | 04:38 PM
IS300TOG35's Avatar
► Matt ◄
I went with 350Z Tein H-Techs having high hopes I wouldnt need a camber kit. After the alignment, my left rear camber was SLIGHTLY out. They set them both the same just a tad out of spec and I could of gotten away without gettin camber arms, but I just got a new set of tires and didnt want them to wear out pre-maturely.
Oh btw, the Z H-tech springs drop the car about .8 in front and .7 in the rear. I would say these springs are the closest you will get to a drop with minimal camber issues. Your only other option is to get the G35 Tein H-techs which drop the car .3 in front and .2 in rear, which will not even be noticed and just a waste of money. For about $550 dollars you could get the 350z tein h-tech springs, spc camber arms and install. Maybe another 50 bucks for alignment a week later and you got yourself about an inch drop... here is a pic of mine.
Rear finger gap:
And the front finger gap:
Hope that helps, good luck
Old May 25, 2005 | 05:37 PM
1nate7's Avatar
Actually, the G H-techs drop it .6"/.3". It doesn't sound like a lot and maybe you want more of a drop, but it is noticable IMO. All alignment #'s were within stock specs but the front camber was almost out at -1.2.
And a comparison (H-techs on left, stock on right):
Old May 25, 2005 | 05:44 PM
IS300TOG35, nice pics. Sorry, I just had to laugh at the last one =X Thats just a caption pic waiting to happen
Old May 25, 2005 | 06:06 PM
IS300TOG35's Avatar
► Matt ◄
get your mind out of the gutter
Old May 25, 2005 | 09:56 PM
GGGunit35's Avatar
Thank you for the help folks.
Looks like I might have to get a camber kit and if so, what kind? Will I need it for the fronts and the rears?
Old May 25, 2005 | 10:28 PM
IS300TOG35's Avatar
► Matt ◄
depends on the drop. If you go with 350Z htechs your rear will need a camber kit. I got SBC rear camber arms to fix it. However if you drop it with other kits that lower the car more then your front may need some extra parts also.
Old Jun 1, 2005 | 03:37 AM
GGGunit35's Avatar
What is a good brand for camber kits? Front and/or back.
boostelevator
Engine - Intake/Fuel
12
Jan 12, 2016 11:35 PM
EasySausage
Sep 24, 2015 01:06 PM
DRG35R
Sep 16, 2015 05:33 AM
Jyounya
Sep 12, 2015 04:03 PM
Kicknshift
Sep 3, 2015 09:35 AM
