What size front tires do you guys recommend?
What size do you guys recommend for the front for a 19x8.5 wheel?
i keep seeing 245/35 , 245/40 and others...what do u guys recommend.....
on the back looks like im going with 285/35......which should fit with no problem at all right?
are you in a coupe or a sedan...? if your in a coupe the rears should fit as long as you have the right offsets and if you are a sedan the rears will be close. as for the tire sizes... the 285/35/19 has an overall diameter of 26.85 inches. the 245/35/19 has a overall diameter of 25.75 inches and the 245/40/19 has an overall diameter of 26.71 inches. i would personally use the 245/40 in the front as it will be with in 1/4 inch of the diameter of the rear.
Originally Posted by Glex25
225/40 on my OEM 19x8.5 Front
05 coupe 6MT
05 coupe 6MT
Go with either 245/35 or 255/35
http://gs.tolan-hoechst.com/tirecalc.htm
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
bTanz
Oct 15, 2015 02:31 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
