Stock vs Lowered...PIX
Old Jun 4, 2005 | 09:02 PM
Gthree5 6MT's Avatar
Here are some shots of my car compared to a stock one.
Both are 2005 6MT (comes standard w/ "Sport Susp. Pkg"
My car has Espelir "GT" springs for 350Z on it.
Just thought I'd show you guys for those contemplating...this is one option...I LOVE IT!!! ^-^
Attached Thumbnails Stock vs Lowered...PIX-lowering-comp-1.jpg   Stock vs Lowered...PIX-lowering-comp-2.jpg   Stock vs Lowered...PIX-lowering-comp-3.jpg
Old Jun 4, 2005 | 09:32 PM
kenchan's Avatar
Are you riding on your bumpstops at that height?
looks good, but functionally might be too low for street to efficiently absorb
the bumps. Are you going to get some D-Specs installed?
Old Jun 4, 2005 | 10:03 PM
CarFanatic56's Avatar
now thats a drop....
Old Jun 5, 2005 | 11:40 AM
vodkarocket's Avatar
Modded Member
That looks absolutely beautiful. Great to see what my car would look like slammed! I give his OEM shocks two months before they blow.
Kenchan- for this kind of setup, would you suggest D-Specs for a G35 or D-Specs for a 350z?
Old Jun 5, 2005 | 03:46 PM
kenchan's Avatar
I would suggest going with the D-Specs for the 350Z since he's running springs
made for the Z.
Old Jun 5, 2005 | 10:29 PM
amg35's Avatar
Florida G35 Club
Looks good, but too low for my tastes.
Old Jun 6, 2005 | 12:08 PM
Modded Member
made for the Z.
I expected that answer. Would these springs matched to the 350Z D-Specs increase the handling potential of the car (vs. sport tuned suspension package), or would the fact that the center of gravity is so much lower in some way detriment handling?
Here is the information I gathered on the Active GT and Super Down springs by Espelir. I am wondering wether I would get better performance/drop from the 350z Active GT or the G35s Super Down.
Active GT
* 350Z / Z33
* Front - 10mm
* Rear - 10mm
* Rate: F-6.9, R-9.2
Active GT
* Infiniti G35 Coupe
* Front - 10mm
* Rear - 10mm
* Rate: F-7.3, R-9.2
Super Down
* Infiniti G35 Sedan
* Front - 40mm
* Rear - 40mm
* Rate: F-4.3, R-6.2
Thanks for the help.
Old Jun 7, 2005 | 01:49 PM
Well, as your info shows...the 350Z Active GT springs' rates are higher than the Super Down for G-Sedan...so, the handling should be better.
However, the G-Coupe Active GT rates are even higher (for the front) than the 350Z...so that should be even stiffer. The rear being the same.
If comfort is of any importance to you, then I'd suggest going w/ the G-Sedan Super Down.
But if its performance you're after, either one of the Active GT...350Z or G-Coupe...will be fine. Besides, they're not stiff to the point of being uncomfortable anyways.
Which ever route you go, though...I'd strongly suggest upgrading your struts as well...either w/ factory "sport suspension" units, or aftermarket units. The basic, non-adjustable KYB or Tokico should make you very happy...and they're reasonably priced too.
Old Jun 7, 2005 | 02:32 PM
Modded Member
Thanks man! The truth is, I am not worried about the stiffness of the suspension, as long as it has the handling dynamics to back it up. I am ready to purchase these springs, and will be mating them to the 350z D-Specs.
My only concern is that there will be too much increased weight transfer to either the front or back, and that my handling will get worse due to such a severe drop.
Old Jun 7, 2005 | 11:03 PM
kenchan's Avatar
Hi Boris,
350Z D-Specs is (from what I read) valved the same as the ones for
the coupes and sedans. Only difference is the shorter body. If those
springs are built for 350Z's, im sure the D-Spec will be able to handle
those springs.
Lowering center of gravity is good for improving handling, but there
are many potential side effects for the change...such as...
not enough sus travel (stroke), roll center being lower causing more
roll, distorted road feedback due to progressive rate springs (if the
list you have are progressive rate), and alignment issues where your
sus geometry is out of spec.
We buy other parts such as control rods, swaybars, dampers to
lessen these sideeffects while improving handling to some degree.
Out of your below choices, I would choose below for best compromise
in looks and styling. The -10mm drop for coupe will go undetected
by most people. The -40mm drop for sedan imho is too low for
street performance.
Active GT
* 350Z / Z33
* Front - 10mm
* Rear - 10mm
hope this helps!
Active GT
* 350Z / Z33
* Front - 10mm
* Rear - 10mm
Active GT
* Front - 10mm
* Rear - 10mm
Super Down
* Front - 40mm
* Rear - 40mm
Old Jun 7, 2005 | 11:43 PM
Modded Member
Thanks for your input Kenchan- I guess I will move forward with this combination.
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
AesonVirus
Engine - Exhaust
Sep 20, 2015 01:54 PM
Tonka211
Sep 18, 2015 09:46 AM
