BRAKE Questions?
Old Jun 23, 2005 | 03:48 PM
G35_Foo's Avatar
BRAKE Questions?
what is better cross drilled or slotted rotors? or the combination of the two? where can i get cheap rotors?
2nd question brake pads what are good out there since my are begining to sqeak a little bit and dont want to risk running into the metal on metal grinding.
Nismo brake pads
Factory pads
project mu
are the three ive seen but i havent been looking yet just browsed one site.
thanks for the help.
-Tim
oh links to sites would be great also
Old Jun 24, 2005 | 01:00 PM
jstwong's Avatar
Try doing some searches for past threads / debates about cross drilled vs. slotted, and for brake pad recommendations.
But essentially, cross drilled rotors can develop heat induced stress cracks if you run them hard enough. So for track use, go with slotted rotors.
As for brake pads... Hawk HPS and EBC Greenstuff are also pads that people have used around here with good results. I've used the EBC Greenstuff in the past and that certainly cut down on the amount of brake dust vs. the stock pads. With my BBK kit, I'm now using Hawk HPS pads from my fronts. So far [I have very little use on them], they seem to be fine.
Old Jun 25, 2005 | 02:47 AM
G35_Foo's Avatar
BBK means big brake kit right sorry for sounding like a noob
jsimonk
Dec 22, 2023 03:49 PM
miata007
Aug 17, 2015 04:36 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
mushu
Jul 15, 2015 03:55 PM
