road noise after spring install?
Old Jun 29, 2005 | 08:56 PM
StVincent's Avatar
i have had Tein springs installed and aligned for a while.. not too sure how to describe the sound, but it sounds like tires are skipping. it is more noticeable when i slow down to stop. car doesn't shake at all regardless how fast i'm driving. it's just the noise that getting on my nerve. i was wondering if there is anything i can do to fix it. do i need re-alignment or is there something wrong with wheel bearing that caused by aftermarket springs? probably camber problem? any input appreciated.
Old Jun 30, 2005 | 01:21 PM
kenchan's Avatar
what are your current front alignment measurements?
maybe tires are feathered or worn out on the inside treads. Did you
check your tires?
Old Jul 1, 2005 | 01:39 AM
StVincent's Avatar
tires looked fine to me, but i will double check. they have about 8500 miles.
the car was aligned after springs were settled.
front
left right
Camber -1.49 -1.84
Caster 9.03 8.87
Toe 0.01in 0.02in
SAI 3.59 8.26
rear
left right
Camber -2.39 -2.16
Toe 0.06 0.06
Old Jul 1, 2005 | 11:03 AM
Zat_Zuma's Avatar
front
left right
Camber -1.49 -1.84
Caster 9.03 8.87
Toe 0.01in 0.02in
SAI 3.59 8.26
rear
left right
Camber -2.39 -2.16
Toe 0.06 0.06
I recommend camber kits for the front and rear and a possibly additional toe kit for the rears. Your alignment specs are way out and you will have premature inside tire wear.
Use these specs and you'll minimize inside tire wear and still have great handling.
G35 coupe alignment specs
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
itztwinki3
Oct 5, 2015 11:29 AM
MyfistYourFace
Aug 8, 2015 11:58 AM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
