dropped on Hotchkis with pics
Old Jul 7, 2005 | 09:09 PM
jeepman's Avatar
had the springs installed today. Went with Kinetx upper control arms to fix the camber issues in the front and the SPC toe/camber kit for the rear. Had it all installed for $300. Couldn't get it aligned at the place that installed it, because it wasn't able to get on the rack because the car sat too low. however, I don't think it would have even fit in the stock form. Going somewhere else tomorrow to get it aligned, first thing.
so far so good...love the ride, and it's the perfect drop to me. Can't wait for the 19's to show up!
Attached Thumbnails dropped on Hotchkis with pics-before.jpg   dropped on Hotchkis with pics-after.jpg
Old Jul 7, 2005 | 09:16 PM
Benj's Avatar
Looking sweet. Most likely going with a similar setup as you have there. You using stock shocks still?
Old Jul 7, 2005 | 09:25 PM
jeepman's Avatar
using stock wheels until the Jlines show up. Hopefully in a few weeks!
Old Jul 8, 2005 | 12:41 AM
kenchan's Avatar
Let the springs settle a couple of weeks before taking it into the alignment shop.
looks good.
Old Jul 8, 2005 | 02:53 AM
truplay8's Avatar
THE BATMOBILE
drop looks great.......which Jlines did you get???
Old Jul 8, 2005 | 08:36 AM
jeepman's Avatar
I would wait a week...but it's way out of wack, and I have to drive it. So...I am gonna get it done today, and then go back in a few weeks.
As far as the wheels...I have the SDMsl2 on order.
Old Jul 8, 2005 | 08:39 AM
kenchan's Avatar
I had mine aligned a few days after then a few weeks afterwards as well.
Old Jul 8, 2005 | 07:57 PM
C_Lawd's Avatar
Are control arms and camber kit necessary for the spring mod?
Old Jul 11, 2005 | 12:22 AM
jeepman's Avatar
to do it right...yes, they were needed.
Old Jul 11, 2005 | 01:19 PM
kenchan's Avatar
To do it right, you need afteramarket dampers as well.
Old Jul 11, 2005 | 08:32 PM
jeepman's Avatar
actually...the hotchkis are very close to the stock spring rate (within pounds) so...no you really don't need to change the dampers out with this setup. I probably will change them out soon anyways...but having the stock dampers are not causing any issues, like not have the camber correted would cause.
Old Jul 11, 2005 | 09:17 PM
kenchan's Avatar
cool, plus they're linear rate, right?
Old Jul 11, 2005 | 09:20 PM
jeepman's Avatar
correct
Old Jul 11, 2005 | 09:23 PM
kenchan's Avatar
i would recommend those Hotchkis over the 350Z H-techs for sure for those
looking for a slight drop. quality wise im sure they're great cause im running
their H-Sport springs on my Cooper-S and they are very well made.
over 2 years use and no sagging either.
Old Jul 12, 2005 | 12:09 AM
jeepman's Avatar
they seem great to me so far. I am going to be looking into their sways next. Honestly, I can't tell a difference from the stock ride. I love it.
