think these'll rub?
Old Jul 27, 2005 | 02:04 PM
user 4560487's Avatar
think these'll rub?
255/40/18 FRONT on 8.5 38mm offset
295/35/18 REAR on 9.5 45mm offset
Sedan on 350z springs...
think they'll rub a dub???
i'll roll fenders if have to, think I will?
of course i'm just day dreaming, i figure when i supercharge my ride i'll need good contact patch to keep it on the road...
wald body kit in dreams too,
Old Jul 27, 2005 | 02:28 PM
Chico's Avatar
You better start rolling or cutting fenders in the rear. You will rub without a doubt.
Your new set up will be exactly 1.19" further out to the fender line in the rear, and 0.67" in the front than your OEM specs. You might be OK in the front.
Old Jul 27, 2005 | 02:32 PM
Chico's Avatar
Wait...i just noticed your current set up. The new set up in the rear will bring the wheels further out to the fender by 0.59"
So take a look now and see how much room you got in rear. I suspect not much.
Old Jul 27, 2005 | 02:40 PM
the 295s killing the deal?
i could go 275/35, but a little short at 25.6, although i currently run 245/40/18 at 25.7, so prob ok i guess
may not want the 255 in front anyways (too wide in front will effect tracking, already a little issue with the 245)
so how about 245/40 and 275/35 on the same wheels?
read somewhere that 9.5/+45 is popular for rear of sedan...
Old Jul 27, 2005 | 02:42 PM
not much, but they don't rub... i think the 275/35 will work, with slight fender roll if i need it...
Old Jul 27, 2005 | 05:42 PM
Chico's Avatar
Your current height is 25.72....your planned height will be 25.58 So no worries here. You won't even notice it and your odometer will be the same.
With 18x9.5 +45, 275/35 you will bring it the wheel/tire out to the fender line by 0.196"
This will work just fine. But to be safe CUT the inner lip fender instead of rolling. When you roll fenders you're risking cracking the paint and would have to paint the entire quarter panel.
Old Jul 27, 2005 | 09:31 PM
where are you getting these numbers?
i have a wheel offset calulator, but doesn't take into account tire width, does what you are using take tire width into account?
Old Jul 27, 2005 | 10:59 PM
Chico's Avatar
Yes. The numbers are as accurate as you can get. Wheel / tire shops can't even give you these numbers.
Old Jul 27, 2005 | 11:09 PM
so where is the magic? care to share?
Old Jul 27, 2005 | 11:58 PM
big daddy d's Avatar
Listen to Chico. HEAR Chico. Obey Chico. Thank Chico Later. I did.
Old Jul 28, 2005 | 01:10 PM
35bills's Avatar
Chico is the wheel and rim guru!!!
Old Jul 28, 2005 | 01:21 PM
sen_jen's Avatar
Meatshake Enterprise
wowsers, those are some super off roading specs!!
DRG35R
Jan 31, 2016 07:14 AM
Popes
Sep 28, 2015 05:14 AM
alinero718
Sep 27, 2015 09:35 PM
