to those who want better handling without lowering..my suspension installed...
Old Jul 25, 2005 | 09:27 PM
accordfreak's Avatar
ok so I finally got my tein basics and the rear SPC camber/toe kit install. It took me a few hours to install so it wasn't too bad. Basic tools with a couple jacks did the job.
I wanted to install it now and not have to worry about camber so I set the height right at stock height until i get front camber kits. Actually it can be set HIGHER than stock height but i don't know why anyone in their right mind would do that. I can already feel the difference in spring rates since the basics are about 200lbs harder than oem.
The handling is much better than stock even though it's not lowered. It virtually eliminated most of the body roll from the stock suspension.
So those of you that don't want to worry about scraping everywhere but want better handling overall, go for the tein basics. A+
as for the install.. you don't have to unbolt the front sway bar. and for the rear you don't have to take off the rear toe bolt if you're installing just the springs.
here are a few pictures....
Attached Thumbnails to those who want better handling without lowering..my suspension installed...-img_3892.jpg   to those who want better handling without lowering..my suspension installed...-img_3889.jpg   to those who want better handling without lowering..my suspension installed...-img_3894.jpg
Old Jul 25, 2005 | 10:50 PM
Infinite1's Avatar
20 Year Member
One question...I'm new to coilovers/dampers....Specifically with the Basics...could you lower it only 1" all around? Would that mess up the camber? TIA for the info!
Old Jul 25, 2005 | 10:57 PM
papagz's Avatar
i have basics too...love it, but its SLAMMEd. i love it low. still smooth and i dont mind the driveways bumps etc, my old car was 3 inches off the ground. still higher than that so im ok
Old Jul 25, 2005 | 11:02 PM
you can lower way past 1" if you want. 1" is no problem. As for camber it's pretty different for everyone. IMO i'd rather not lower it until i get the front camber kit just to be safe. I don't want to spend money on tires right now when i don't have to.
Old Jul 25, 2005 | 11:09 PM
ozracer01's Avatar
awesome coilovers for sure...while they are new. My fiance has em on her IS300 and after about a year and half, the coilovers have become very bouncy, as if the gas or oil(not sure whats inside of em) have failed. Its dropped about 1.5 all around and she only drives to school and around town(no road racing or anything like that). We even adjusted the damper setting to something a little stiffer to hopefully prevent the long range bouncing, but it just made it worse. Hopefully the ones for the G35 are designed better, and i'm hopeful you won't run into these problems at stock height.
Old Jul 25, 2005 | 11:24 PM
Gsedan35's Avatar
But Tein tell's us that you cannot install Basics on a G35 coupe without at least a .7" front drop. Granted they can be installed with the rear set to no drop, but not the front. Basics installed on a sedan have a minimum front drop of 1.6"
http://www.tein.com/infiniti.html
Old Jul 27, 2005 | 12:05 AM
DannoG35's Avatar
Its interesting to see posts on Tein lately. There seems to be a lot of controversy about wheather they are good quality or not.
Old Jul 27, 2005 | 09:47 AM
Infinite1's Avatar
20 Year Member
Hmmm....Good point Dan....I'm relatively new to Tein as i've had Eibachs on my 93 Integra waaaaayyyyyy back in the days.....They seem pretty well known....But in retrospect i have heard good things about Tein too...i definitely like to hear more!
Old Jul 27, 2005 | 01:42 PM
kenchan's Avatar
and why would you need a toe/camber kit if you're not lowered?
I was expecting a thread using stock springs and aftermarket
dampers (koni, d-specs, etc).
Old Jul 27, 2005 | 01:50 PM
imalazeeass's Avatar
he said that hes not going to lower until he gets a camber kit
Old Jul 27, 2005 | 02:17 PM
kenchan's Avatar
but his front is already 0.7" lower...according to Gsedan35... no?
Old Jul 28, 2005 | 08:27 AM
Gsedan35's Avatar
Follow the link and read the chart.
Tein basics when installed on a G35 coupe will lower the front of the car .7" when set at the max ride height settting. Of course at a .7" front drop a coupe should be within oem camber specs.
Old Jul 28, 2005 | 12:50 PM
maybe my car is a freak? or maybe it hasn't settled. Before I installed the basics I measured the wheel gap. When I finished the install it was the same.
Old Jul 28, 2005 | 01:32 PM
SinG35c's Avatar
Ummm...just ordered mine, hope I won't get the same results in a year
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
