help! Z suspension
Old Jul 31, 2005 | 06:11 PM
cloudy6MT's Avatar
help! Z suspension
Just installed the Z suspension myself - checked and double checked everything. Now when I start moving the car slowly and making a slight turn of the wheel, I hear/feel a small pop coming from the front suspension. Also happens when I go in reverse.
Everything else is fine, just this small annoying problem. Anyone got a suggestion? Thanks in advance.
Old Aug 1, 2005 | 02:37 PM
dklau33's Avatar
Did you torque down all the nuts and bolts to factory spec? You might want to double check on those.
Old Aug 3, 2005 | 11:34 AM
Gsedan35's Avatar
Carefully place a cresent wrench behind your sway bar end links that bolt to the lower suspension and tighten them. I had a noise that I finally cured doing this. Now the only thing I hear is the front upper rubber spring seats at speeds less then 3mph as the car comes to a stop and even that I can barely hear, oh windo's down too.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
