19x9.5 on sedan offset question?
Old Aug 5, 2005 | 03:40 AM
Augy's Avatar
Would 38mm be okay on the sedan? I seen some cool wheels. 19x8.5 and 19x9.5 with 38mm all around. Would this setup work with my car being dropped? Thanks!
Old Aug 5, 2005 | 10:14 AM
Chico's Avatar
The ideal set up for the sedan is:
front 19x8.5 +35 to +38 w/ 245/35/19
rear 19x9.5 +45 to +43 w 275/30/19
That will give you a perfectly flush look all around and no rubbing.
Old Aug 5, 2005 | 10:15 AM
KayGee56's Avatar
well what would be a perfect set up to have all 4 the same all around so you can rotate them?
Old Aug 5, 2005 | 10:17 AM
Chico's Avatar
19x8.5 +35 w/245/35/19 is a perfect fit.
Old Aug 16, 2005 | 05:59 PM
wanalaugh74's Avatar
So a +25 would not work on a sedan?
Old Aug 16, 2005 | 06:10 PM
vodkarocket's Avatar
Modded Member
Not even close!
Old Aug 16, 2005 | 06:14 PM
G35Frank's Avatar
I DID A +36 OFFSET WITH 19X8.5 255/35/19 IN FRONT AND A +49 OFFSET WITH 19X9.5 285/30/19 IN THE REAR. HAVNT HAD ANY RUBBING ISSUES YET. CHECK IT OUT.
https://g35driver.com/forums/g35-sedan-v35-2003-06/64053-finally-got-my-wheels.html
Old Aug 16, 2005 | 06:17 PM
G35Frank's Avatar
ANY WHEELS WITH DECENT TIRES ARE GONNA BE DIRECTIONAL ANYWAYS. YOU CAN'T ROTATE THEM WITHOUT DISMOUNTING THE TIRES.
Old Aug 16, 2005 | 06:39 PM
aam6906's Avatar
cant really rotate staggered rims buddy no matter what the offset..........
bu villain
19 Inch
Nov 15, 2015 09:23 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
reaper76
Aug 5, 2015 10:13 AM
