rims and tire size
Old Aug 11, 2005 | 09:06 PM
coc's Avatar
coc
rims and tire size
Is there any reason not to get 4 identical tires on 17 rims for a 6MT 03 coupe? I know the OEM specs are for a 18 rim with slightly larger backs than fronts.
Thanks, I am new to G35s and this forum.
Old Aug 12, 2005 | 02:23 PM
ceraaa42's Avatar
Traction controll & ABS problems if you don't keep the front to rear ratio the same. The stock sizes differ fr to rear.
Chris
Old Aug 15, 2005 | 01:46 PM
P_Diddy's Avatar
I use 4 equally sized tires for auto-x. When I first got them installed and pulled out of the tire shop with them on, the SLIP light came on. I turned off VDC and I have not had that problem since. Plus, I can't break them loose because they stick like crazy
Just turn off VDC. I have not noticed any ABS problems yet. What are you going to use the 17" rims for?
vitamin.v
Nov 7, 2019 06:10 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
paolojericho11
Sep 11, 2015 07:08 AM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
